Triumph TR7 Engine Weight
Postby bmcecosse » 11 Sep 2013 14:13
How heavy is a TR7 engine? I have the chance of one locally - but am wondering how I could collect.
Postby FI Spyder » 11 Sep 2013 14:20
Don't know the weight but it's heavy. When I pickup up my engine/trans that Ron gave me, I used his engine crane to put it in a friends little Toyota truck and mine at the other end to lift it off. With out the transmission I still don't see it any other way. Maybe I'm just weak.
Postby bmcecosse » 11 Sep 2013 14:29
Sadly no 'truck' available...it will have to go in the back of the V V V V Morris Traveller....
Postby Workshop Help » 11 Sep 2013 15:23
My memory is a little fuzzy on this, but. I seem to think the LT77 weighs about 85 lbs and the engine in the vicinity of 325 lbs.
Dan B
Postby Dan B » 11 Sep 2013 16:53
285#
Postby dursleyman » 11 Sep 2013 18:50
Its a two man lift. When I collected one with a mate we thought someone had bolted it to the ground!! Its not a problem so long as you expect it.
I would suggest a flat load bed (like a van or estate) so you don't have to bend or you will knacker your back.
1980 TR7 Sprint DHC
Postby bmcecosse » 11 Sep 2013 20:27
Thanks lads...I have a couple of spare LT77 boxes - not too bad for weight. This would just be an engine - with an alloy head....is it really that heavy??
Postby saabfast » 11 Sep 2013 20:34
Agree with 2 man lift - with effort! I collected two from Maxwell when he was clearing his shed - heaviest engine I have ever lifted. My son and I struggled with them and they crushed a small 2 wheel trolley I had. We had pulled an engine from a Viva a few weeks before. It is all iron but comparatively a fly weight.
Saab 9000 2.3 FPT Auto
Saab 9000 2.3 LPT Auto
mrpatatomoto
Postby mrpatatomoto » 12 Sep 2013 04:06
When I rebuilt mine it took all I had to pick it up and put it on the engine stand. That was before I put the head on.
~Mike
1975 TR7 FHC
scribe
Postby scribe » 12 Sep 2013 06:27
Very heavy (can only trust the weights listed above).
I have an engine with gearbox sitting on my driveway. Every time I pass it I rub my chin for a few seconds wondering how on earth I'm going to get it to the back of my house (only access is through the house).
I'm sure it will have to be taken apart and then the heavy bits taken through the house on a trolly....... Then somehow get it back when it's rebuilt....... I must remember that some things aren't problems; they're opportunities to succeed [:)]
Postby Hasbeen » 12 Sep 2013 07:21
I used to be able to carry my Ferguson tractor engine, the TR3A engine in my Morgan +4 with some difficulty, single handed.
No way I can do the same with the TR7 engine.
Ianftr8
Postby Ianftr8 » 12 Sep 2013 09:20
Should go in the back of the Morry Traveler without too many problems, as long as you put something in the back first to spread the weight (pallet?) and make sure you you lash it down so it doesn't move about and cause loads of damage.
It is a pretty heavy lump that will need lifting in and out with an engine crane - certainly a two man job!
Good luck!
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
Postby Don » 13 Sep 2013 23:55
Just for fun, there is in interesting table of engine weight here:
https://www.scribd.com/document/1739669 ... ight-Chart
The Triumph slant-4 is listed at 290lb = 131kg (source - Complete Handbook of Automotive Power Trains, Jan Norbye, 1981)
TR7 engine weight.JPG (24.45 KiB) Viewed 8106 times
Limey7
Postby Limey7 » 14 Sep 2013 02:34
Sounds like it'd make a great boat anchor![:)]
"The Flying Doorstop!"
Postby Workshop Help » 14 Sep 2013 12:15
Now the actual engine block is not all that heavy. It's when you add the crankshaft, flywheel, pressure plate & disc, cylinder head, and all the rest of the internals that it all starts to sag your biceps.
The bare block itself, while no mere whistle in the breeze, is just hefty enough to be strong. Besides, lifting engine blocks is all part of an approved cardio-vascular restoration regimen.
