Bit of help
Bit of help
Postby stevie_a » 04 Aug 2013 15:22
<b><font color="teal">can someone do me a favor and post a photo of the dash pod with the ignition on so I can see what lights go on
Does the coolant light come on ?</font id="teal"></b>
Postby Beans » 04 Aug 2013 16:17
Yes, together with ignition and oil
Postby stevie_a » 05 Aug 2013 15:53
<font color="teal"><b>Thanks Beans
not got coolant light but I am doing a lot to the dash just now
will post later on what I have been up to </b></font id="teal">
<font size="1">very cryptic </font id="size1">
Postby Beans » 05 Aug 2013 16:22
In that case easy to check if the bulb is blown,
other culprit is corrosion on the sender in the header tank.
Is it really that cryptic [:p]
Postby stevie_a » 05 Aug 2013 16:41
<font color="teal"><b>yip I am changing my dash about
also found new style led lights for the said coolant and ignition etc
just trying to get it all working and forgot what should go on with ignition.</b></font id="teal">
dmtrmp6
Postby dmtrmp6 » 07 Aug 2013 10:27
Stevie,
Be aware that ignition light (bulb)typically forms part of the excitation circuit for the alternator. LED unlikely to function correctly in this role. Typically leave conventional bulb in the ignition warning socket.
To excite the alternator on initial turn on, 12 volts flows from battery via bulb (lights up) to excite alternator field winding. When rotating/generating output volts the alternator will self excite and at same time provide 12 volts back to the alternator warning bulb effectively cancelling out the 12 volt supply from battery (equal volts both side of bulb = no current flow = no bulb on).
Hope this helps.
Regards, Daryl M
Postby stevie_a » 07 Aug 2013 16:17
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dmtrmp6</i>
Stevie,
Hope this helps.
Regards, Daryl M
<font color="teal"><b>You are sooooo Right
never even entered my thick head.
"TA"
the new led light in the other slots make a massive difference
when the sun is on the dash you can still see them clearly
jrich4411
Postby jrich4411 » 07 Aug 2013 22:00
Stevie - what did you use for all these bulbs?
'80 DHC
Chevy V8 up front
Ford rear end down back
Lucas wiring all over
Jolyon39
Postby Jolyon39 » 07 Aug 2013 23:03
Odd is the one to ask about LEDs for this purpose, he sold us all LED kits with photographic instructions about 4 years ago.
Gosh it may even be 4+ years ago......
Here is the link
http://www.forum.triumphtr7.com/topic.asp?TOPIC_ID=8855
Jolyon
Users browsing this forum: No registered users and 275 guests
