argh, bonnet
camaroneil
argh, bonnet
Postby camaroneil » 25 Jul 2013 15:33
help,
took the car for it's mot today,
pulled bonnet catch, it clicked and popped up but i had to give it a real hard tug (no comments please) to get it to come free,
got home and now when i pull the bonnet catch it pops up the first little bit but then feels solid,
i've tried putting a screwdriver thru the mesh and everything seems to be moving as it should,
anyone have any ideas before i have a few beers and get the angle grinder out and just cut a big hole in the bonnet????
cheers,
neil
tr7 dhc, V12 xjs, discovery, 70 mustang, 98 cadillac sts
Postby John Clancy » 25 Jul 2013 15:45
Pull the rubber seal out (the middle one inside the area covered by the fresh air duct) and get yer wifey to stick her little fingers in and move the bonnet release over. It's slightly offset from the middle more to the left when looking from the back of the car, but if she can feel it then it should be fairly easy to move it over. Then hopefully the bonnet catch will fully release.
Before you shut it again make sure you haven't caught the cable up in the fresh air duct. Always check the cable is free after having the duct out and before closing the bonnet.
camaroneil
Postby camaroneil » 25 Jul 2013 16:37
hi,
thanks for that,
i already got a screwdriver in and the lever moves all the way across,
i'm starting to think it's the actual catch with the spring on that is not centered in the hole,
cheers,
neil
j.johnson23
Postby j.johnson23 » 25 Jul 2013 19:34
When you do get the bonnet open take the 2 bolts out and cut a good slot into the top of them and screw them back in
When you close the bonnet you can access the slots through the mesh and loosen them,then tighten them with a screw driver.
Open the bonnet and if it opened ok you can nip them up with a spanner.
Don`t go too tight,if the problem reoccurs you can loosen the bolts with a screwdriver.
I was advised to do this and found it very successful.
All the best.
parrish
Postby parrish » 26 Jul 2013 12:16
pull the bonnet one way or another when trying to open.
1983 Del lines TR8. FIAT 131 Abarth Replica.1977 FIAT 131 1600 TC, 1996 BMW Z3, 1960 Mini Hustler. 2009 Sport Ka, 2012 Ford Fusion.
camaroneil
Postby camaroneil » 26 Jul 2013 14:46
well,
tried everything,
so ended up hacksawing the rod in half,
job done,
neil
Ianftr8
Postby Ianftr8 » 28 Jul 2013 08:58
when you put the new spigot in, how about cutting a slot in the end that screws into the bonnet - you could then (if it gets stuck again pass a screwdriver through and just unscrew it from the top.
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
Users browsing this forum: No registered users and 289 guests
