Fuel senders
Fuel senders
Postby dursleyman » 17 Jun 2013 23:01
Putting a "new" fuel tank in my TR7 and I find I have two different kinds of fuel senders. It looks like one is an original type and one is a modern replacement.
They both give similar readings with a test meter so I propose to use the original type and wondered if anyone has thoughts either way?
The original type also has a rubber ring on the float (not shown in pics) which seems to be a bump-stop to prevent it hitting the bottom of the tank.
1980 TR7 Sprint DHC
Postby Hasbeen » 18 Jun 2013 04:59
My original sender was as your top unit. It was still going strong, until the second time I pulled it out.
It did have a little petrol in the float, which I removed by drilling a small hole in it, shaking the fuel out, & plugging the hole with a bit of wood. This swelled as wood does in water & sealed perfectly.
It was still working when I pulled it out to do something to the tank, but not after it was put back. I had shaken the thing around too much, & broken the already well worn wire in the winding.
It was very well worn, so I would use a new one if available. Incidentally that wood plugged float is on the new sender now. When changing to a new tank I found the float on the new sender was about 1/4 full of petrol in about 3 years, & switched to the old one.
Postby stevie_a » 18 Jun 2013 18:11
<font color="teal"><b>I was looking at mine tonight
how do these fix in place?</b></font id="teal">
Postby stevie_a » 18 Jun 2013 18:38
<font color="teal"><b>Had a look I see now. retaining ring.</b></font id="teal">
Postby Odd » 19 Jun 2013 12:04
Before you refit either of them into the tank (to be forgotten for another 35+ years, hopefully) I'd recommend you
take that plastic 'will fill with petrol over time'-type float off and fit the VERY similar brass float from Ford.
An ordinary modern-fuel resistant O-ring will mimic the function of the by now old and cracking rubber ring...
Postby dursleyman » 19 Jun 2013 17:29
Odd, I have seen the posts about the Ford float option but I seem to recall them referring to USA stuff, can you point me at the same item in Europe?
1980 TR7 Sprint DHC
Postby Odd » 20 Jun 2013 06:18
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Odd, I have seen the posts about the Ford float option but I seem to recall them referring to USA stuff, <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Yes, lots of US Fords use it.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> can you point me at the same item in Europe? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> No. But it's easy to get it from the US.
Moss even have them in stock now - thanks to Kelvin... Part number is 360-646 and Price is USD 10.95
http://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=108851&SortOrder=10
Not much of a trouble for decades of piece of mind imho...
Postby dursleyman » 20 Jun 2013 10:37
Thanks Odd, I'll check them out.
Looking at their list it looks like it will fit almost all the British cars of the era so I bet someone here has them as well.
Watch this space.
1980 TR7 Sprint DHC
Postby DNK » 20 Jun 2013 12:17
1 caveat, people in the 6 crowd have had them come loose.
So you might want to tack on a little solder
Stick a Wedge In It
Postby Hasbeen » 20 Jun 2013 14:41
Do use some care when tightening the lock ring.
It was after removing & refitting my sender recently that my 7s tank started leaking between the main tank, & the fitting the sender fits into.
The lock ring was tapped quite gently, with a drift & a small rubber hammer, not hammered wildly, but it broke the solder seal.
Users browsing this forum: No registered users and 278 guests
