gauge reads full
gauge reads full
Postby stevie_a » 08 Jun 2013 14:57
<font color="teal"><b>My fuel gauge reads full but the low fuel light came on
silly I thought the gauge was correct
nope ran out of fuel today [:I]
can you take the sender out without lowering the tank?
I cant remember.</b></font id="teal">
RJS
Postby RJS » 08 Jun 2013 16:38
Read this thread. I helps to explain how to test the sending unit and figure out where the problem is.
http://www.forum.triumphtr7.com/topic.asp?TOPIC_ID=15400&SearchTerms=sender,ground
Rob
John Wood
Postby John Wood » 08 Jun 2013 17:55
Pretty sure you can get it out steve without moving the tank. Just remember the sender will be full of fuel even it the tank was empty. Not a nice job.
TR7 Sprint SJW550S
tr7jim
Postby tr7jim » 08 Jun 2013 19:46
Stevie,
You can take out the tank sender without removing the tank. If the gauge is reading full maybe your two wires have been swopped over so circuit is not going through the resister in the sender?
Not a nice job, its helps if the front is higher than the back so the fuel towards the back of the tank. I always think my tanks empty and I usually fill up two / three fuel cans.
Jim
Postby FI Spyder » 08 Jun 2013 19:52
Driving around for days with the tank always full has got to be the ultimate definition of an optimist.[:D]
When I removed my tank I drove it until the low fuel light came on. With the car up and level I removed the sender, no problem.
Postby stevie_a » 08 Jun 2013 19:54
<font color="teal"><b>Don't think it is the wires as the car was fine when it went into the garage for the winter</b></font id="teal">
Postby jclay (RIP 2018) » 08 Jun 2013 20:21
If the gauge reads full, you probably have a short some where. I would look at the top of the driveshaft tunnel at the rear bulkhead, right where the wires go into the cockpit at the rear of the console.
RJS
Postby RJS » 09 Jun 2013 00:16
I am assuming that if the low fuel light is working, then it is getting that info from the sending unit, so I would think that the problem is somewhere else.
dycecooper
Postby dycecooper » 09 Jun 2013 06:42
I have the same problem, gauge reads full, if I disconnect the wire from the sender unit it reads empty, re connect it reads full, new sender unit did not fix it either.
Postby stevie_a » 09 Jun 2013 07:33
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RJS</i>
<font color="teal"><b>good point the light seams to work fine</b></font id="teal">
Postby saabfast » 09 Jun 2013 18:24
When my gauge read full all the time I checked the connections on the sender but was all OK. I changed the gauge to cure it, been fine ever since.
Saab 9000 2.3 FPT Auto
Saab 9000 2.3 LPT Auto
Postby stevie_a » 09 Jun 2013 19:07
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by saabfast</i>
When my gauge read full all the time I checked the connections on the sender but was all OK. I changed the gauge to cure it, been fine ever since.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
<font color="teal"><b>I have a spare dash in the garage I think it has a guage int I will give it a go
when I get the time...[B)]</b></font id="teal">
tr7jim
Postby tr7jim » 10 Jun 2013 19:21
Stevie,
For the fuel gauge to show full when the tanks empty the Green/black cable to your sender must be going down to body earth.
You can quickly chek the fuel sender by unplugging the Green / black cable at the fuel tank sender, if the gauge shows low then its the sender unit internals. With the gauge showing full deflection the gauge is working ok.
If the gauge is still shows full, it must be going to earth, so need to check the wire run underneath along the gearbox area first, etc. Hopefully just the cable needs repair.
The only other option is to fill the car up and carry on till the low fuel light comes on and go to fuel station. suggest also carry some fuel in suitable container.
Hope this helps, can have you missing the sun you ordered for billing?
Jim
Postby Maxwell » 10 Jun 2013 19:27
My gauge works - goes up and down more or less as it should when fuel goes in or out, but the tell-tale low fuel light is kaput. Ran out of fuel with the gauge showing just under a quarter-tank yesterday.... or, put another way, just above empty!
Maxwell [:I]
<b>2.0 TR7 Drop head \ Maxwell \ sold
2.0 TR7 Fixed head \ Robyn \ sold
3.5 TR7 V8 Drop head \ Oliver \ sold
2.0 TR7 Fixed head \ Ben \ current
0.7 Smart Roadster \ Oscar \ current</b>
Postby stevie_a » 10 Jun 2013 19:31
<font color="teal"><b>On what you say Jim
I think it is going to earth in the dash as my alarm had to be replaced also before I put the car on.
I hope I did not have a visit from my little friends the mice.</b></font id="teal">
Users browsing this forum: No registered users and 215 guests
