Mystery holes in the floor
Postby dursleyman » 16 May 2013 20:04
Apart from the headlight problem (see other post) I found a couple of mystery holes in the floor of my "new" TR7. There is a rectangular hole in the floorpan that you can see the ground through on each side of the car. Its inside the crossmember below each seat, looks like someone has taken out a grommet to get access to add wax and not put them back - see the picture.
Can't find them in the parts list, any ideas where I get some please?
1980 TR7 Sprint DHC
Postby Beans » 17 May 2013 05:11
Never seen a hole there, safe for some created by tinworm [:D]
Postby Maxwell » 17 May 2013 05:33
Ah - The Square-Munchin Rust-Bug strikes again! Never seen that before..
Maxwell [:(]
<b>2.0 TR7 Drop head \ Maxwell \ sold
2.0 TR7 Fixed head \ Robyn \ sold
3.5 TR7 V8 Drop head \ Oliver \ sold
2.0 TR7 Fixed head \ Ben \ current
0.7 Smart Roadster \ Oscar \ current</b>
Ianftr8
Postby Ianftr8 » 17 May 2013 07:06
Has someone cut out the pin that you use to locate the jack?
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
Postby dursleyman » 17 May 2013 07:35
I have the same rectangular hole on BOTH sides of the car and it opens into a crossmember under the floor. The lower crossmember has a couple of oval shaped holes that's why I noticed I could see the ground!!.
I'll add some measurements and a couple morepictures to locate it later.
1980 TR7 Sprint DHC
Postby dursleyman » 17 May 2013 16:12
I have either solved the mystery - or made it worse.
Looking further I found two more holes of the same size with nice rubber grommets in, see the picture. Grommets are approx 40mm by 30mm and all the holes seem to be original.
So any idea of a part number for the grommets?
1980 TR7 Sprint DHC
Postby Beans » 17 May 2013 16:21
All looks rather strange to me.
LH side footwell ...
RH side footwell ...
Early 81 DHC
MikeRotherham
Postby MikeRotherham » 17 May 2013 17:15
The new coupe bodyshell that was recently for sale on ebay appeared to have the same oblong holes in the passenger footwell and not the large round hole.
Were the later bodyshells modified/improved I wonder?
Mike.
dycecooper
Postby dycecooper » 17 May 2013 18:48
These holes are for version 5 Flux Capasitors, but at that age it would have been an after market kit for sure
supercass
Postby supercass » 17 May 2013 19:19
So looking at these pictures, under normal circumstances would the oblong holes would be hidden from top viewing by the standard soundproofing mat? supercass
Postby dursleyman » 17 May 2013 23:59
So its a puzzle then. If it helps the car was first registered on 01/08/1981 and is VIN:TPADJ7AT214099 so does that make it a late shell?
Maybe it was a change from the earlier shells but these are definitely production holes and I need two of the grommets to fill them.
1980 TR7 Sprint DHC
Postby john 215 » 18 May 2013 04:39
I can remember seeing these square holes on lots of BL products, some even had gromets in them on certain models in certain places where they were visible ie. under bonnets etc, poss Maestro / Montego. At a guess used on production for tool location during assembley [?]
1976 Speke FHC Beauty
Postby busheytrader » 18 May 2013 08:48
I'm restoring / preparing a classic Mini Cooper for circuit racing. The inner sills have lots of rectangular holes which take grommets. I don't know the exact size hole you've got to fill but Mini Spares stock this grommet to suit. http://www.minispares.com/product/Class ... ommet.aspx 1" long by 13/16". Maybe two cut about could fit?
Alternatively a small piece of 1mm polythene sheet could plug the gap with Tigerseal or similar sealing around the edges from above and below? That would probably be a more permanent fix than a grommet.
Postby Beans » 18 May 2013 15:17
... TPADJ7AT214099 ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That makes it a Canley built car.
As the car in my pictures is a later Solihull car this seems another one in the category <i>"BL-mysteries"</i> [:D]
Postby dursleyman » 21 May 2013 12:37
Just to round off this subject, I asked Robsport about the missing grommets and they knew what I meant but didn't know a part number.
They have sent me a couple of old ones so I will be able to block the holes in my floor properly!
1980 TR7 Sprint DHC
Users browsing this forum: No registered users and 165 guests
