Has anyone tried this?
Ianftr8
Postby Ianftr8 » 13 May 2013 14:52
Over the last few months I've been experiencing squealing noises from the fan / altenator belt on my 8.
I don't want to overtighten the belt because I don't like the feel of the new waterpump I fitted when I rebuilt the engine a couple of years ago.
So to give me a little bit of fine tuning I have pinched one of the headlamp raise / lower adjusters off a spare headlight pod (RTC1992) with it's brass bush
Has anyone else tried this or can see a reason why it wouldn't work or collapse because it's not strong enough?
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
Henk
Postby Henk » 13 May 2013 16:16
Maybe this will do the job:
http://www.stationaryengineparts.com/Anti-Slip-Belt-Dressing.html
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Ianftr8
Postby Ianftr8 » 13 May 2013 16:33
Thanks for that Henk- I have already tried a similar belt dressing
Interesting web site - has given me some inspiration for something else I've had laying around in the garage for a while.
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Postby john 215 » 13 May 2013 17:16
Hi Ian,
Got one of Clint's from Wedge Shops turn buckle adjusters works a treat, so I guess a shorter version should work. Once the alternator is tight its not like that it will doing a lot.
http://www.thewedgeshopstore.com/produc ... r-TR8.html
1976 Speke FHC Beauty
Ianftr8
Postby Ianftr8 » 13 May 2013 17:29
Thanks John,
Seems to fit Ok - but would like to look at Clint's offering - are you going to Gaydon on Sunday?
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Postby john 215 » 13 May 2013 17:38
Hi Ian,
Will be there, will if I remenber put a mirror in the boot as not the easy to see tucked down the front
Users browsing this forum: No registered users and 185 guests
