Battery hold down kit
farrikt
Postby farrikt » 06 May 2013 18:03
Just put a new correct size battery into my TR7,old one was too large for the plate. Although it should be an easy job I can not see how to fit the "Battery hold down kit", (bought from Rimmers). Anyone else had this problem or got a clear picture of one in position that
I can look at ? Thanks.
Kevin
Postby nick » 06 May 2013 18:43
Kevin,
If you bought the kit that has the angle iron and two "J" bolts then you may need to do a modification to make it work. I found a hole on the firewall side of the battery rack to take one of the bolts. But I had to drill the rack to take the forward one. The original fasteners on my '80 car had some clamps that attached to the rack. They required a battery with molded ears at the bottom that accepted the clamps. The good thing about the after market kit is you have a wider choice of batteries.
'79 TR7 DHC
'76 TR7 FHC
Postby DNK » 06 May 2013 19:07
Off topic ,but your pic reminded me of something that I just noticed.
I had a K&N filter on our 03 Accord.
Went to clean it the other day and popped the hood and noticed
There is a paper filter in there.
Not only that , the Sticker that was on the box was gone. You can still see the outline.
Went back thru the receipts and it happened when I was in Wa.
Should have paid more attention to the adviser and paper work
Stick a Wedge In It
farrikt
Postby farrikt » 06 May 2013 19:08
Thanks for this, the picture really helps.
Kevin
Milanoverde
Postby Milanoverde » 06 May 2013 20:05
I bought the kit from VB and found the same problem. I went to the auto parts store and bought a generic hold down bolt kit which were longer and solved my problem
Postby FI Spyder » 07 May 2013 00:52
I used two uneven length J clamps. One fits in hole in firewall area and other in the hole in turret as there is no provision in the tray.
You can see the longer silver J clamp as goes to the turret. I put some heat shrink on the clamps so there would be no metal to metal contact so the paint wouldn't wear/chip off.
Postby nick » 07 May 2013 14:24
Stick a Wedge In It
Don,
Just goes to show, if you want it done right do it yourself.
'79 TR7 DHC
'76 TR7 FHC
Spectatohead
Postby Spectatohead » 07 May 2013 15:37
The Ford F-150 I have has a K&N sticker on the air box. I too was surprised to find a paper filter inside when I went to clean the filter. It happened before I owned the truck and they left the sticker in place. I guess we have idiots everywhere throwing away these expensive things replacing them with paper, or maybe its just here in Washington state?
Jim Clark
'80 TR8
'97 Maxima 5spd
Users browsing this forum: No registered users and 276 guests
