1980 TR7 2L lost a fan at speed
tya2agt
Postby tya2agt » 29 Apr 2013 17:22
Dear List,
Lost the fan assembly yesterday while travelling at 110 KMH, Not the plastic bits, but the whole freaking cast assembly plus blades came off. Symptom was heater suddenly started to generate heat and then the temp gauge climbed. Stopped lifted the hood and the fan was wedged into another part of the engine compartment. Tried putting it back on the shaft but it just spins loosely. Put some rash marks in the back of the radiator and broke off a small aluminum vane on the metal casting. Fixed the hole in the rad with stop leak and with the help of stream water and some coolant was able to get out of the mountains and back to civilization.
So what is supposed to hold the fan on the shaft? Anyone else lost a fan assembly? What do I need to buy from Victoria British, a fan and the metal casting? or is there something else I am not seeing the parts catalogue?
Reg 1980 TR7 Convertible
80 TR-7 Convertible
tr7sprint1
Postby tr7sprint1 » 29 Apr 2013 17:34
baering (caged needle/tolerace bearing).
Postby FI Spyder » 29 Apr 2013 18:36
Hind sight is 20/20. That banshee wailing probably wasn't alternator belt slipping but the fan viscous clutch giving up the ghost. At that point the correct move would have been to take off fan belt and put on shorter one to turn alternator. You don't need the fan when driving on the highway (a hundred miles from anywhere). A failing viscous clutch can disintegrate. Ron (Orange Rag) had his fan clutch fail in Portland and drove back to Nanaimo with no fan (fan belt off). At least you don't have to go through Edmonton city traffic.
You don't want to overheat the engine (warp the head) so watch that gauge and make sure you have lots of water to refill if necessary.
When back safely you can get a new clutch/fan/tolerance bearing or many at this point go with an electric fan.
I told you it would be an adventure.[8D]
Postby Beans » 29 Apr 2013 18:53
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tya2agt</i>
... So what is supposed to hold the fan on the shaft? ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
A rather cheap steel tolerance ring, (clearly visible in the picture below is an old (and flattened) ring
And they should always be replaced, never ever re-use them
(as you have just witnessed what can happen when you do [B)])
Postby bmcecosse » 29 Apr 2013 21:41
I would not attempt to refit it - there must be a reason it came off! Either do without - it will be fine unless stuck in summer traffic - in which case use the heater or switch off when not moving, or fit an electric fan. I have to ask - is the engine noticeably quieter without the fan ??
Postby jclay (RIP 2018) » 29 Apr 2013 22:47
https://googledrive.com/host/0B8MWEvqOpX3udEF4SmFQUW9RS09hbU5uNW5Wd0xrUQ/Changing%20the%20Fan%20Sleeve.pdf
tya2agt
Postby tya2agt » 30 Apr 2013 00:14
Ok got the replacement parts, some new the compression seal, some used the viscous clutch, and some reused the plastic fan. Ok How do you get the viscous clutch over the compression wheel on the shaft?
My son and I had a go at it tonight and could not force the clutch over the seal on the shaft. It was easy to see why the previous clutch had failed, as a groove had worn on the internal surface of the old clutch. The old compression ring was no where to be seen.
\So how to do you get the viscous clutch over the compression ring. Do I have to pull the rad and try and hammer it on? We even tried compressing the compression ring with a tie wrap while we tried to slice the viscous clutch over the compression ring and the shaft?
Thanks Reg
80 TR-7 Convertible
Postby Beans » 30 Apr 2013 07:48
The viscous coupling should be pressed on the pulley assembly.
No way you get that done with the assembly on the engine.
A hammer and a proper drift (so you don't damage the coupling) and good support underneath the rotating part of the pulley should do the trick.
Don't support it under the mounting face as this might damage the pulley's bearing
And bear in mind that it can be a pain in the @rse to refit the assembly to the engine [B)]
Postby Cobber » 30 Apr 2013 12:40
<font size="2"><font face="Comic Sans MS">Just another reason why all viscous fans should be binned!
A stupid overly complicated way of doing a simple job!
</font id="Comic Sans MS"></font id="size2">
'98 MG-F, 69'Ford F250.
Postby FI Spyder » 30 Apr 2013 13:08
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Cobber</i>
Must be why Jaguar used the same part.[:D]
Postby Cobber » 30 Apr 2013 14:08
And I thew the one on my Jag in the bin too!
Postby Beans » 30 Apr 2013 16:52
After which you probably started to complain on cooling issues [:p]
Or sold the Jag of course [:D]
troydeon
Postby troydeon » 30 Apr 2013 17:37
Wow Reg sorry to hear about the fan...
Sounds like you were kind of lucky with minimal damage.
I had a 240z that had the water pump go out and when the shaft shifted the fan almost cost me my radiator...
Troy
1980 TR7 DHC
