emergency switch
sparkymario
emergency switch
Postby sparkymario » 24 Apr 2013 17:32
Anyone know where I can get a warning switch in dash for flasher????
supercass
Postby supercass » 24 Apr 2013 22:44
Do you mean a hazard flasher or full beam? Don't understand what you mean by a warning switch? A switch with a warning light? supercass
vitessesteve
Postby vitessesteve » 25 Apr 2013 09:52
Hazard warning light switch?
Steve Weblin - AKA vitessesteve
1982 TR7 Sprint DHC
sparkymario
Postby sparkymario » 25 Apr 2013 10:50
the warning light switch in dash for 4 way flasher everywhere i check seem to be discontinued
supercass
Postby supercass » 25 Apr 2013 11:24
So it is! Seems quite an unusual part to be in scarce supply. There are however two used on U.K. ebay at the moment. (Buy it now) at about £8 each inc post to U.K. Where are you? supercass
Postby Maxwell » 25 Apr 2013 11:25
Item number:181125667603
<b>2.0 TR7 Drop head \ Maxwell \ sold
2.0 TR7 Fixed head \ Robyn \ sold
3.5 TR7 V8 Drop head \ Oliver \ sold
2.0 TR7 Fixed head \ Ben \ current
0.7 Smart Roadster \ Oscar \ current</b>
sparkymario
Postby sparkymario » 25 Apr 2013 13:34
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by supercass</i>
i live in Canada
Postby FI Spyder » 25 Apr 2013 13:36
Is it broken? They can break at the pivot point.
Is it just dirty? They corrode and can be disassembled and cleaned. Inside are copper contacts that can be polished clean with Brasso or other metal cleaner, put a little di-electric grease on them so they don't recorrode, reassemble and it's as good as new. mark what is top of switch and body. Take pictures before you take out contacts so you know how they go back in with out having to think about it.
Do that same with the headlight switch while your at it.
Wouldn't hurt to do external contacts and contacts in plastic block if you want to be thorough.
vitessesteve
Postby vitessesteve » 26 Apr 2013 07:34
S & S Preparations, Robsport and the Spitfire Graveyard all UK based traders should be able to help. They have lots of used stuff.
1982 TR7 Sprint DHC
Postby bmcecosse » 27 Apr 2013 19:29
A squirt of WD40 in the switch every now and again keeps it healthy, and I make a point of USING the switch every time I run the car. Otherwise - it stands unused from one MOT test to the next one....and then it fails......
Users browsing this forum: No registered users and 30 guests
