Front hub bearings
Morley Faulkner
Front hub bearings
Postby Morley Faulkner » 23 Apr 2013 20:09
Hi All,
I am just about to start machining a set of alloy hubs for my TR7V8. I have fitted 4 pot calipers and Toyota Supra rotors. I need to beef up the outer bearing on hub.
Does anyone know the bearing number of the larger replacement bearing.
Original number LM 11749/LM 11710.
Benzo
Postby Benzo » 23 Apr 2013 21:00
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Morley Faulkner</i>
Hi All,
Would it not be cheaper to just buy a set some complete with uprated bearings and then have your discs redrilled?
Currently back to Basics with my BMW V8 Engined Build.
Benzo
Postby Benzo » 23 Apr 2013 22:06
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Vegas_M</i>
Is this what you want?
http://www.ebay.co.uk/itm/Triumph-TR7-TR8-Race-Rally-Alloy-Front-Hub-With-Bearings-and-Studs-/180835248787?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a1a9eea93
Those are what I was going to suggest. Surely cheaper than commissioning a set yourself? Unless ofcourse you plant to do the lathe work yourself?
Morley Faulkner
Postby Morley Faulkner » 23 Apr 2013 22:18
Hi Benzo,
Thanks for info, but not as cheap as making them yourself when you are a retired Toolmaker and have your own engineering workshop.
Benzo
Postby Benzo » 24 Apr 2013 06:57
Hi Benzo,
Ahhh I wish I had your skills :(
Postby DNK » 24 Apr 2013 11:16
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Benzo</i>
[quote]<i>Originally posted by Morley Faulkner</i>
Hi Benzo,
Or,...I'll take a set
Stick a Wedge In It
Postby FI Spyder » 24 Apr 2013 14:18
I'll take the workshop too......skills can be learned.[8D]
Postby Beans » 24 Apr 2013 17:51
... I need to beef up the outer bearing on hub ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Why? I haven't had any problems with them over the years.
And I dare say, my front bearings get above average loads with rather sticky tyres ...
And beefed up suspension with bigger brakes ...
Alloy hubs look rather nice though [8D]
Postby john 215 » 25 Apr 2013 05:11
Had a close look at Alastairs hubs at Stoneleigh and they are very sexy indeed [8D]
An original bearing is on the stud, although not that clear it is smaller than the one fitted to the hubs
Not to mention very light
1976 Speke FHC Beauty
Morley Faulkner
Postby Morley Faulkner » 25 Apr 2013 23:54
Hi John,
If you look closely you can see the rollers are bigger diam than in the original. Can not read the bearing number in hub.
Morley Faulkner
Postby Morley Faulkner » 26 Apr 2013 01:30
If you bought one of the Alloy hubs advertised, which is a copy more or less of the original hub, and want to fit the larger disc, you then have to fit a spacer between hub and disc. Now the kit offered by Rimmers has a steel spacer and it weighs 2.1kg. So making the whole unit on alloy makes sense. Just finalising drawing before starting to machine. Will let you know how I get on.
Postby john 215 » 26 Apr 2013 05:02
It was only when I got home I thought to myself that should have took a picture of the larger bearing so the part no. could be read, I think this question has come up before [?]
The only close up picture I took close up was I am sorry to say out of focus [:o)] [:(]
Would be great to see your progress, my father was a toolmaker and know from him what skilled guys you are.
Postby dursleyman » 26 Apr 2013 14:56
Morley, I reckon if you are not careful you will be getting lots of orders for your new hubs.
1980 TR7 Sprint DHC
Morley Faulkner
Postby Morley Faulkner » 26 Apr 2013 20:46
Hi Dursleyman,
Thanks for that, but I'm to old and to cynical to believe that will happen. How ironic I served my time as a Jig & Toolmaker at Standard-Triumph in the old Flechampstead toolroom 50 odd years ago, now gone full circle and I am back doing it again. I see from your profile you dabbled in rallying Rootes products, did you work there? An old Mate of mine now deceased Colin Malkin did a lot of rallying in Imps.
Users browsing this forum: No registered users and 16 guests
