Poor running/crankcase ventilation
prlee
Postby prlee » 23 Apr 2013 17:47
Not to happy with the TR7. I had a problem a week ago when one of the camshaft cover nuts went walk about, leaving oil over the engine bay.
I have replaced the offending item and fitted new rubber washers to all the remaining nuts, replaced the spark plugs (due for a change) and the ignition leads which were covered in oil.
But the engine is not as smooth as it was (for a basic 2.0 Ltr engine anyway).
I noticed oil over the rhs engine, not sure how it got there.
I took the car for a run last night and it runs very nicely and revs well, no power problems and reasonably smooth.
Tonight I started the engine and noticed oil vapour coming out of the dipstick tube. I thought this suggests there could be a problem with crankcase breathing. I haven't checked the compression yet, I will do that tomorrow.
Any thoughts? and how does the crankcase breathing work.
Pete
Image Image Image
jeffremj
Postby jeffremj » 24 Apr 2013 06:06
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Any thoughts? and how does the crankcase breathing work.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Check the tube from camshaft cover to carbs:
prlee
Postby prlee » 24 Apr 2013 17:24
Thanks, I thought it was only through the top breather tubes. Checked them tonight, blew down them (yuk)and no problem. Tried a compression test but couldn't get the gauge on properly. I will try again on the weekend.
Maybe there isn't a problem, but then again could be piston rings.
Pete
Image Image Image
Postby Beans » 24 Apr 2013 17:56
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by prlee</i>
... but then again could be piston rings ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Wire filter gauze inside rear of cam cover might be blocked with muck.
If that is free and the engine is still pressurizing through the dip stick tube you might be right there [B)]
prlee
Postby prlee » 24 Apr 2013 20:23
Thanks Beans, breather is okay so I fear the worst.
Other commitments means I will most likely have to put the car into storage for few years.
Pete
Image Image Image
prlee
Postby prlee » 27 Apr 2013 11:08
Did the dreaded compression test today, no 4 failed, virtually no compression. The rest were around 6 bar, but I dont know how accurate it is.
Now what to do, I dont really have the spare cash or time to spend on it at the moment, in its current condition its probably not worth selling.
Looks like I need to find someone with a trailer so I can get down to to my parents for storage. Chap next door has a 1980's SD1 V8, been on axles stands for years mmmmmm.
Pete
Image Image Image
claypole1360
Postby claypole1360 » 27 Apr 2013 16:12
Pete, where are you based, I have a trailer. Clayps.
What's that coming over the hill? Is it a monster?
1978 TR7V8 FHC
1968 Bond Equipe Sprint Car
1962 Herald Coupe 1200
2003 Peugeot 206 GTI
2009 VW Passat
prlee
Postby prlee » 28 Apr 2013 05:06
Thanks Clayps, looks like you're in lincs, I'm in gloss so not local. Hiring a trailer does not look expensive, tame the TR down and bring the Spitfire back, just need a tow bar.
Pete
Image Image Image
Users browsing this forum: No registered users and 30 guests
