Ooooh no cars!
prlee
Ooooh no cars!
Postby prlee » 16 Apr 2013 17:33
3 cars all taxed and mot'd and none work [xx(]
Modern VW in for a new clutch so chance to run through 7 for a few days, already had a few good outings this year.
But first day in the way home there's clouds of blue smoke from the bonnet vents and in the car, b*****r. Managed to get home, or even of the camera cover nuts has disappeared and oil sitting out over the engine etc. Not got a spare.
The spitfire is taxed and mot'd but 50 miles away and stripped for a bonnet respray.
Some days things just don't go your way.
At least the garage has a loan car.
Pete
Image Image Image
trekcarbonboy
Postby trekcarbonboy » 16 Apr 2013 17:36
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Managed to get home, or even of the camera cover nuts has disappeared and oil sitting out over the engine etc. Not got a spare.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Huh??[?]
Craig '75 2.0 FHC
prlee
Postby prlee » 16 Apr 2013 18:41
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by trekcarbonboy</i>
[quote] Managed to get home, or even of the camera cover nuts has disappeared and oil sitting out over the engine etc. Not got a spare.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Predictive text huh.
Back on the PC now.
Basically on the way home there was clouds of blue smoke, turned out she had lost one of the cam cover nuts. Oil was spitting out from the hole all over the engine and exhaust. [:(!]
So three cars and none working (ok a grommet could provide a temporary fix). Anyway new parts are on the way.
In the meantime the VW is still off the road as the parts supplier sent the wrong flywheel for the right clutch.
The garage is very good, the job is taking a lot longer than planned and the extra costs are being covered between them.
Pete
Image Image Image
claypole1360
Postby claypole1360 » 16 Apr 2013 18:46
Hi Pete, sorry to hear you're without classic, glad you've been using the TR a bit though, been following the progress of the spit on the other site.
Clayps.
What's that coming over the hill? Is it a monster?
1978 TR7V8 FHC
1968 Bond Equipe Sprint Car
1962 Herald Coupe 1200
2003 Peugeot 206 GTI
2009 VW Passat
prlee
Postby prlee » 16 Apr 2013 20:02
Thanks Clayps, hopefully TR back in action tomorrow evening, VW back on Friday and Spitfire bonnet respray this weekend.
Better news for the TR is that I have found a supplier of cellulose paint in the right colour. So summer respray is on the cards.
Pete
Image Image Image
prlee
Postby prlee » 17 Apr 2013 17:00
The replacement nut and a set of washers arrived this morning and have just been fitted.
No more smoke but there are a couple of concerns.
The engine is running a rough, I dont know but this could be due to the soaking the ignition leads had from the oil. I will clean it all up when I get time.
Second concern, I removed the oil filler cap with the engine running. The cam box area was pressurised, is this normal for the TR7, I had expected to find negative pressure?
Any thoughts?
Pete
Image Image Image
Postby gaz » 17 Apr 2013 17:37
how much pressure do you call pressure, its perfectly normal to have some degree of pressure in there, If you take off the oil cap and replace it you'll feel some resistance or are you talking full blown hisss hisss.........
1981 DHC 2.0 Litre
1980 DHC pedal car
1976 FHC 2.0 Litre
prlee
Postby prlee » 17 Apr 2013 18:06
Not really sure, oil fumes coming out. I put my hand over and could feel it. I know on the Spit I expect negative pressure.
Pete
Image Image Image
Postby gaz » 17 Apr 2013 20:39
Sounds normal me.....
1981 DHC 2.0 Litre
1980 DHC pedal car
1976 FHC 2.0 Litre
Postby Hasbeen » 17 Apr 2013 22:54
I've never known an engine that was not pressurised. An F100 Ford V8 I once owned was like a steam train.
Don't forget the timing chain is spinning around right under the oil filler cap. Centrifugal force, as it runs around with the cam pulley, will throw oil everywhere, with the cap off while the engine is running.
prlee
Postby prlee » 18 Apr 2013 04:06
Thanks all, hopefully cleaning the plugs and leads will sort the rough running.
Pete
Image Image Image
Users browsing this forum: No registered users and 30 guests
