<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by kstrutt1</i>
other items I have found which helped were poly bushes on the inboard end of the control arms and replacing the wheel bearings (even though there was no apparant Issue).
Good point. Additional things I did between when I had it and when it disappeared forever was: replace ball joints and tie rod ends (They looked good but I had everything out and parts in stock so replaced them anyway.) I put hard black poly bushings on the front end. Did my own wheel alignment with string. New shocks and regular springs. Grease the rack. Replaced brake caliper piston seals as a matter of course. Now none of these caused the problem I believe, except the hard poly may have given it a bit of stability.
When you get to this stage, do it all, do it right.
