Pretty Sure...
Pretty Sure...
Postby DNK » 08 Mar 2013 17:31
It's not suppose to look like this.
Both sides look like this
What is it for and where did it connect.
Very forward edge of the hood (top)
Stick a Wedge In It
darrellw
Postby darrellw » 08 Mar 2013 19:37
Yeah, it should be pop riveted to the header rail. I'm not sure, but I may see the head of the pop rivet where it should be directly above your hand.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
whitenviro
Postby whitenviro » 08 Mar 2013 19:57
Yep. We've talked about this a couple times before; you need a rivet (and rivet washers or it will probably just tear out again). Getting a rivet gun in there can be difficult. I drilled out the rivet and replaced it with a tiny little bolt with washers and a locknut.
[/img]
Postby DNK » 08 Mar 2013 20:12
There doesn't seem to be a hole on it.
It looks like it ripped or came unsewn
Stick a Wedge In It
supercass
Postby supercass » 08 Mar 2013 20:33
If I recall correctly on the original hoods there was a small flap attached to the edge and the rivet went through this. supercass
Postby DNK » 08 Mar 2013 21:33
What's it for?
Stick a Wedge In It
Users browsing this forum: No registered users and 106 guests
