Triumph engine fire
Last TR
Triumph engine fire
Postby Last TR » 14 Feb 2013 20:44
This puts all of our little Triumph problems in perspective...
http://www.npr.org/blogs/thetwo-way/201 ... nival-says
Ken Morton
Anchorage, Alaska
Image Image Image
Postby FI Spyder » 14 Feb 2013 22:19
Just watching it on CNN. Couldn't they have named it Carnival MG? At least with the Triumph name it will get them home (with help).[:p]
Postby Hasbeen » 15 Feb 2013 00:51
Don't most Triumph's need the occasional recovery effort?
These people obviously don’t check history, before naming their ships.
Last TR
Postby Last TR » 15 Feb 2013 04:25
Carnival Lines has everything from the Carnival Breeze to the Carnival Victory. Other than the Carnival Triumph, I think my favorite would be the Carnival Miracle. Clearly what these folks needed.
Ken Morton
Anchorage, Alaska
Image Image Image
Spectatohead
Postby Spectatohead » 15 Feb 2013 05:14
I've never had toilets back up in any of my Triumphs.
Jim Clark
'80 TR8
'97 Maxima 5spd
Neil_W
Postby Neil_W » 15 Feb 2013 08:05
The toilets work on a Vacuum system so when there is no power on the ship the toilet vacuum system stops.
The toilet bowl won't open as there is no vacuum to whoosh it away so any No.1's & No.2's you do just sit in the bowl hence the cabins & toilets are full.
When you have 100's of people having a poo it doesn't take long for it to get out of hand.
Built in 1999 the Carnival Triumph is quite old - if you go Cruising stick with modern Tonnage which have 2 completely seperate Enginerooms which each can fully operate the ship if there is a problem.
Quote from the BBC -Carnival has cancelled more than a dozen planned voyages aboard the Triumph, while acknowledging that the crippled ship had other mechanical problems in the weeks before the fire.
You get what you pay for on Cruise's - cheap = old cheap ships
Saying that the Concordia was new & she went bump - strange run by same Company !
Last TR
Postby Last TR » 15 Feb 2013 17:21
Jim Clark
I have had pump failures in my Triumphs though...
Ken Morton
Anchorage, Alaska
Image Image Image
Morley Faulkner
Postby Morley Faulkner » 16 Feb 2013 00:08
I've been in the crap a few times with mine.
Users browsing this forum: No registered users and 168 guests
