Heated rear window
Heated rear window
Postby nick » 14 Feb 2013 14:47
Does the heated rear window have a relay? If so where is it. Victoria British shows it as a part without showing a location. Rimmer does not have it and I can't find it in the Leland manual.
'79 TR7 DHC
'76 TR7 FHC
RJS
Postby RJS » 14 Feb 2013 18:50
This might help. I am not smart enough to understand, but I do not see a mention of a relay. Technically this is for TR8, but I am sure this is no difference for the rear window demister.
Bottom middle of the first page inside detail A.
http://www.team.net/TR8/tr8cca/wedgelab/other/schematics/TR8_schematics.pdf
Postby nick » 14 Feb 2013 19:39
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RJS</i>
Thanks for that drawing. It does not appear that there is a relay there. It surprises me because I thought that system would have a fairly high current draw. Perhaps it doesn't. I don't have access to the car at the moment but it would be interesting to see what amperage fuse is in the box.
'79 TR7 DHC
'76 TR7 FHC
Postby jclay (RIP 2018) » 15 Feb 2013 00:30
There is a relay there bigger than Dallas.
Postby REPLIC8 » 15 Feb 2013 06:29
Nick,
Look at "detail A" in the little box at the bottom. deffinately a relay in the system, and looks like a 15 amp fuse in location 3-4. [:)]
RJS
Postby RJS » 15 Feb 2013 13:47
Quick hijack of post....
Hi Clay. I had not seen you post in a while. Nice to see you back.
Rob
Postby nick » 15 Feb 2013 23:05
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by REPLIC8</i>
Nick,
Now this I can understand. Thanks for your patience [^]
'79 TR7 DHC
'76 TR7 FHC
Postby Workshop Help » 15 Feb 2013 23:24
Just a small hint; please check the wires on the inside of the glass have not been scratched in two. This happened to me in 1978 and was repaired using a continuity repair kit. It's worked fine ever since.
Postby nick » 16 Feb 2013 18:57
[quote]<i>Originally posted by Mildred</i>
Thanks for that tip Mildred. Do you know where the relay is located? My relay panel has a total of 4 relays, 2 headlight, one starter, one air conditioner. I found another air conditioner and one horn relay in the engine bay.
What is in a continuity repair kit?
'79 TR7 DHC
'76 TR7 FHC
Postby Workshop Help » 16 Feb 2013 21:11
The 'kit' consisted of a small brush, a bottle of a gooey/liquidy copper solution, and a slotted piece of paper. The repair method involved cleaning off the glass area, placing the slotted paper over broken area, and daubing on the goo. Once it dried the electrical current was restored and the heating element worked.
As for the relay, I haven't looked for it.
Users browsing this forum: Cobber and 127 guests
