Air Condioning / Heater Matrix Rebuild
cozyheatdave
Postby cozyheatdave » 04 Feb 2013 18:19
I have the AC/Heat unit out of one car, and a heat only unit out of another. I want to rebuild the AC/Heat unit.
Has anyone attempted this before and documented the progress?
Seals, Controls, improvements, ? ? ?
Thanks
Dave
I couldn't repair my brakes, so I made my horn louder.
[img=left]http://i1239.photobucket.com/albums/ff504/tikvahmarketing/Forum_pic.jpg?t=1324940124[/img=left]
Postby FI Spyder » 04 Feb 2013 23:48
I had mine out but that was to replace foam seals (made up from foam i had handy)and foam facing on the flaps (thin foam sheets from craft store). The rubber was still good so that remained undisturbed. All moving parts were lubed and any screwed connections checked for tightness. Electrical connections cleaned and dielectric greased. Flushed out the matrix with some CLR.
HDRider
Postby HDRider » 05 Feb 2013 14:13
I had the one in the TR8 out a couple of years ago to replace the heater matrix. It is a non AC unit. I actually bought a used one on E-Bay and went through it first so that the car would not be down as long. Pretty straight forward. I picked up foam sheets at a local hardware store and refaced all the flaps. Cleaned and lubed everything up. That was about it.
It took a full day to remove and replace the unit in the car.
Edward Hamer
Petaluma CA
cozyheatdave
Postby cozyheatdave » 06 Feb 2013 13:46
I was wondering how to find the foam sheets. Never thought of a craft store. I'll check the hardware too.
The system seems pretty basic, but a lot of small parts. If anyone has step by step pictures or videos send the link :)
Thanks,
Dave
Postby Beans » 06 Feb 2013 15:29
Some info in my weblog under Heater ...
cozyheatdave
Postby cozyheatdave » 08 Feb 2013 13:59
Thanks Beans. You always have great pics, and great inspiration.
Really, when I think about it, my whole project is your fault. I would have been done by now with a simple daily driver... but I was inspired to go the extra mile.... or million miles.
Dave
[img=left]https://lh6.googleusercontent.com/-uManpLbY1O0/URUgWYSnOyI/AAAAAAAACQE/oqLYsbLU5aQ/s200/2012-02-18_14-10-35_502.jpg[/img=left]
Users browsing this forum: No registered users and 383 guests
