Battery Gadget....
Battery Gadget....
Postby Maxwell » 01 Jan 2013 15:23
Hi Guys... Black & Decker make a 'booster' to start a car with a dead battery [from another] by linking their cigarette lighter [accessorary]sockets, rather than by a set of heavy-duty jump-leads.
Has anybody any experience of using these? They retail on Amazon for around £15 \ £25.
Regards Maxwell [;)]
<b>2.0 TR7 Drop head \ Maxwell \ sold
2.0 TR7 Fixed head \ Robyn \ sold
3.5 TR7 V8 Drop head \ Oliver \ sold
2.0 TR7 Fixed head \ Ben \ current
0.7 Smart Roadster \ Oscar \ current</b>
Postby stevie_a » 01 Jan 2013 15:58
<font color="teal"><b>I have a great pair of jump leads that i have had for about 20 years
recently i was asked by my sister to help her get her car started, she could not get it going
with her jump leads, so i went over put my jump leads on and the car started first time.
I mentioned to her she should get a new set of leads and these would be perfect
but i am dubious if they are any good
I wait to be corrected by someone that has used them.</b></font id="teal">
j.johnson23
Postby j.johnson23 » 01 Jan 2013 16:29
Believe it or not but if you only have a flat battery and not a knackered one these actually work.
The secret is to connect it up and leave the battery to charge for 15-20 mins,then disconnect the lead and start the car.The donor car needs to be kept at a fast tickover.
They are a good idea as they can be kept in the car and don`t take up as much room as jump leads.
Its not a good idea these days to try and start off jumpleads-you can get a voltage spike that will damage one or both cars electronics.
darrellw
Postby darrellw » 01 Jan 2013 16:29
No experience, but just looking at the wiring for the "booster", and the wiring to the lighter socket should tell you that you are not really going to get much current via that path. It might be OK to charge up the "dead" battery a bit, but that would take some time, and might be just enough to start a car when the battery is just barely below the threshold.
I had an MR2 once where the battery was dying. It was able to turn the engine over, but the voltage dropped enough when doing so that the ECU wouldn't turn on, so the car would not start. I suppose if you were in that kind of situation, this gadget might be enough.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby Cobber » 01 Jan 2013 20:28
<font size="2"><font face="Comic Sans MS">Junk!</font id="Comic Sans MS"></font id="size2">
'98 MG-F, 69'Ford F250.
Postby FI Spyder » 02 Jan 2013 13:59
I wouldn't want to try and start a car relying on the wire coming from/going to the cigarette lighter. I went for one of these smart chargers that charger at 2 amps then maintains with pulse. On sale flyer for $20, normally $40/$50. Better than my $10 2A battery charger that was no more than an AC/DC converter. Aaaah, progress.
Users browsing this forum: No registered users and 158 guests
