Coolant
graybeard
Coolant
Postby graybeard » 01 Jan 2013 07:28
My brother passed away and when we started his TR7 the coolant light came on, when I tested the coolant it was ok to 0 degrees. it is 2 degrees here in Wisconsin now.
Do I need a different mix of coolant?
Thanks in advance for replies
HowardB
Postby HowardB » 01 Jan 2013 10:32
On the later cars the coolant light measures the level in the expansion tank. It will go out when you top the tank up - I usually fill the expansion tank up and then let it find its own level when the engine has warmed up. Any excess will discharge through the overflow
Happy New Year and hope the car finds a good new home
Howard
RadioGuy
Postby RadioGuy » 01 Jan 2013 10:34
The coolant light does not "test" the coolant mix. I believe it only tests the coolant level. If your coolant level is very near the top of the radiator then the problem is probably electrical.Follow the wires coming from the sensor located on the side of the radiator ( I think it is on the passenger side) disconnect clean and re-connect the sensor electrical connector.
Edit: Ok, it's been awhile since I've been under the hood/bonnet of my TR with the leaky head gasket....[:I]. But the theory is still sound. If your coolant level is ok then you have an electrical problem and I would start at the sensor.
Maintained on Saturday…Drive on Fun-Day !!! 1976 FHC - 1980 DHC http://tinyurl.com/7rkonrx
Postby FI Spyder » 01 Jan 2013 13:54
The sensor is not by the side of the radiator, that is the temperature sensor that turns on the electric fans when the temp gets too high. These fans also turn on to cool the condenser when the A/C is turned on. If you don't have A/C you wouldn't have the fans but may still have the temp switch in the side of the radiator. I believe new radiators are only available with temp switch for A/C compatibility.
As Howard says the coolant light is turned on by sensor in the brass expansion tank as found on the later LH tanks were it was moved to make way for the air cleaner/air mass meter on the RH side found on FI cars and was used on carb cars for compatibility sake. It measures coolant depth (not mixture) as it is critical so the engine doesn't over heat due to not enough coolant and warp the head. Normal coolant height is about second knuckle of finger down from top of filler hole. The rest of room in tank is for coolant expansion as it warms up and expands. If you have too much coolant it will harmlessly go out the overflow tube except for the mess it makes on the garage floor (and resultant danger to pets) when you turn the engine off and you get that last bit of expansion from the heat spike when it stops circulating. If you have to keep adding coolant it may be that the system is expelling air in the system (as when you change coolant) or it is leaking. That may be from the radiator (leaving tell tale signs of blue/green residue), from the hoses (either cracked or loose clamps) or (commonly) from the failed seal in the water pump where it gets passed and leaks out the rectangular hole on the left side of the block below the intake manifold leaving a tell tale sign of leakage or on no longer painted engines a rust trail down. This necessitates removing intake manifold and pulling the pump to replace seal/bearing and gaskets in a rebuild kit and/or pump. Much has been written on that subject and must be read before attempting it, many of us have done it, not me (yet). Don't leave it to a mechanic not familiar with the slant 4 engine as it will be buggered up by him if not done right.
Users browsing this forum: No registered users and 225 guests
