Exhaust paste?
Exhaust paste?
Postby REPLIC8 » 28 Dec 2012 16:37
I have some nicely reconditioned cast manifolds to fit on my TR8 to replace the cracked ones it has at present. I'm unsure whether to install them dry with just the gaskets or to also use assembly paste. I don't really want white paste splodging all over my lovely grey manifolds but I also don't want to have to remove them again if they leak. What's the best way for a clean job with no leaks?
Neil_W
Postby Neil_W » 28 Dec 2012 17:12
From an Engineering prespective - if the recon manifold is square ie flat & the cylinderhead face is flat you shouldn't need any paste.
A good quality gasket will seal the faces when bolted up.
Use copper based 'coppaslip' on the studs though when assembled.
Postby FI Spyder » 28 Dec 2012 19:34
The original exhaust manifolds didn't have gaskets just bare metal to bare metal, only the FI cars did although it's recommended to put gaskets on if you have the manifold off. So with that in mind, unless your manifold is warped you shouldn't have any problems with just gaskets.
Postby busheytrader » 30 Dec 2012 16:33
Hi Andy,
When I bought my V8 conversion kit from S&S, they advised me to fit their tubular exhaust manifolds to the heads with RTV paste and <u>no</u> gaskets.
Over 20 years and they're still leak free.
Postby john 215 » 30 Dec 2012 17:18
Hi Andy,
I hope you are feeling a lot better now,
Never needed to use any paste on any manifolds I have ever fitted, would certainly use copperslip on all threads though, I know how lovley and original your car is so not really applicable but a head to manifold studs make life easier.
1976 Speke FHC Beauty
Ianftr8
Postby Ianftr8 » 30 Dec 2012 18:24
Andy,
I have four branch manifolds which I do use gaskets to make the seal - I have never found that I have needed to add any sort of exhaust goo to help.
The only thing, in agreement with John is to use copperslip on the studs and if you can get hold of them brass full nuts.
Regards
Ian
Ian Freeman
1979 TR8 DHC
Triumph Courier
Triumph owner for 31 years
Postby REPLIC8 » 31 Dec 2012 08:18
Hi Andy,
Hi John,
Getting there health wise, recovering from a heart attack I had in August, but hope to get some jobs done on the car soon and get out and about in it in the summer (if we get one!!).
Thanks for all the replies, looks like I'll be just using gaskets. I have some new brass nuts to attatch the downpipes as well. [:)]
Users browsing this forum: Google [Bot] and 233 guests
