headlight flash question
manny
Postby manny » 01 Nov 2012 16:44
Good day all,
i have been looking at how the headlamp flash can be redirected to the Aux\drving lamps only if the pods are not raised, i have got this far on paper, can anyone verify if this will work?
http://flickr.com/gp/89581871@N08/658n1P
or if any other methods have been used successfully
cheers
Manny
Reliant Scimitar GTE 6a 78
Kawasaki ZX636R
Piaggio fly 125
manny
Postby manny » 02 Nov 2012 11:08
don't hate me.....
TR7 V8 1982
Kawasaki ZX636R
Piaggio fly 125
Postby TR Tony » 02 Nov 2012 11:18
Crikey Manny, I haven't got a clue if that would work.
I think you need someone clever with electrics like Odd to comment ....
manny
Postby manny » 02 Nov 2012 13:32
TR TONY!!!
thanks for replying!! i know i read a topic in which some one mentioned such a set up..but that was last year, but thanks all the same.
[:)] Manny
TR7 V8 1982
Kawasaki ZX636R
Piaggio fly 125
Tom M.
Postby Tom M. » 03 Nov 2012 11:24
Yes the way you drew it up should work. When the main beams are down, the fog/driving lamps will flash, otherwise the main beams will flash.
The only issue I see is that it will take 4 relays to implement this, how often do you do it? At least it doesn't seem like it should impact the reliability of the normal headlights switch.
Tom M.
manny
Postby manny » 04 Nov 2012 15:06
Hi Tom,
i suppose the (default) main issue is that the 'Flash' occurs before the headlight pods actually raise, it should save the the flash stalk switch contacts as well. Although i have used 5 relays, i recently purchased an Arduino kit..pushed into it my a work colleague, and looking at if power MOSFETS can used instead, still on a steep learning curve though.
Manny
TR7 V8 1982
Kawasaki ZX636R
Piaggio fly 125
Tom M.
Postby Tom M. » 09 Nov 2012 16:51
Wow an Arduino would do it indeed but it's quite a bit of overkill.... the switches are in the +12 V line so you can't use N channel FETs with the source grounded (the only way the Arduino can directly control the FETs). You'll need N channel FETs with a high side driver or really big P channel FETs. Either way a relay would probably end up being easier.
Tom M.
manny
Postby manny » 12 Nov 2012 18:32
Hi Tom
overkill...of course...but as i am not a programmer or electronics whizzy....my goal would push me to learn.
The chap who nudged me to buy it has set up a laser tracking face recognition robot...why!!!!!??????.... i do not know....i guess because he could...he spent around 80 pounds.for fun
I don't understand why he thought that would be a cool idea!
I suggested he make it portable , program it to recognise rats and attach it to his cat..that i can understand
i also want to use it to control the rad fan on my Scimitar and TR.
But the Scimitar will be my test bed for the Arduino plus just bought temp sensor and 20x4 LCD....let the games begin!!
Manny
TR7 V8 1982
Kawasaki ZX636R
Piaggio fly 125
Users browsing this forum: No registered users and 276 guests
