Engine Vibration
prlee
Engine Vibration
Postby prlee » 13 Oct 2012 16:47
For some time I have been working on the high speed vibrations in the car. This has improved over the last year significantly. I now think whats left is to do with the rear wheels/tyres but I have also identfied that some of it is engine.
This is felt on the gear stick (its not from the box) and steering. I can feel it rising and falling with engine revs not road speed.
Question is is this normal and can it be reduced. I will be going over the engine tomorrow, checking distributor and carburettors as well as tuning and timing.
The car has a standard small bore mild steel exhaust system and the engine is completely standard.
Any thoughts?
Pete
Image Image Image
Milanoverde
Postby Milanoverde » 13 Oct 2012 16:58
I'm thinking shifter bushings and/ or transmission mounts. Tony
prlee
Postby prlee » 13 Oct 2012 17:29
Thanks Tony, but both have been replaced.
Pete
Image Image Image
Postby FI Spyder » 13 Oct 2012 18:28
There is going to be some engine vibration on a 4 cylinder engine of this vintage. Manufacturers struggled to minimize this in some engines with things like counter rotating balance shafts. I prefer to think of it as a desirable characteristic of the age kind of like when airline pilots climb out of their 747's and for fun go for a spin in their Stearman Biplanes.
kstrutt1
Postby kstrutt1 » 13 Oct 2012 18:47
They are not the smoothest of engines so some vibration is normal, check the engine to gearbox bolts and mount bolts are tight, beyond this if it running well there is little you can do, also it may improve when you fix the wheel imbalance, this can excite the engine on it's mounts.
Postby Hasbeen » 13 Oct 2012 23:02
It could be an unbalance in the clutch gear.
Try hitting the clutch while going down a ling hill, then try with the thing in neutral, with the clutch in & out. If there are any changes to your vibration that should help reduce the possible causes.
prlee
Postby prlee » 14 Oct 2012 15:23
Didn't have the time I had planned today, to many other things needed doing.
However did try the engine in neutral clutch in and out and didn't notice any difference.
However I did take the cap off the distributor cap off and found the mechanical advance was very stiff and probably not working. Its either fully advanced or wont advance. This was not really a surprise as I found the same thing when I got the car.
I didn't have time to sort it this week, will have to wait to next weekend. Car runs ok but will not be on top performance, could this give rise to more vibration?
Pete
Image Image Image
Users browsing this forum: No registered users and 11 guests
