chirping noise from rear
Sautie
Postby Sautie » 07 Oct 2012 08:23
some long time ago I asked if anyone new of a cure for a chirping noise from the rear of my 8 only heard on overun. New wheel bearings, new prop shaft & overhauled diff had not resulted in a cure. Well now it is cured all because of a second set of eyes when fitting new break shoes. It was noted that the brake backing plate was mounted 90degrees out. This was rectified & delight delight the chirping noise has gone,[8D]
Postby FI Spyder » 08 Oct 2012 00:09
Sometimes it's the simplest thing. A good rule of thumb, when diagnosing make no assumptions.
Postby Hasbeen » 08 Oct 2012 01:18
Well spotted.
Thanks for telling us.
