Instrument Cluster foam seal ?
slob.h@tiscali.co.uk
Postby slob.h@tiscali.co.uk » 29 Aug 2012 18:08
Does anyone know of a suitable near as original replacement for the grey foam strip fitted to the top and bottom of the instrument cluster ?
Postby Hasbeen » 29 Aug 2012 21:41
I use a 1/2" X 3/16 neoprene foam rubber strip, with one side adhesive. It is available from most marine shops, & specialist rubber outlets.
Ordinary foam rubber is not much use, as it compresses completely in a very short time.
Postby john 215 » 30 Aug 2012 04:53
[:D] WELCOME TO THE BEST TR7 / 8 FORUM IN THEVWORLD EVER [8D]
How about a look around B & Q and such like, maybe some draft excluding foam, the sort used around window's etc [?]
1976 Speke FHC Beauty
Postby andyf » 30 Aug 2012 05:51
I did just that, bought a roll of self adhesive foam strip from a DIY store.
1980 Persian Aqua DHC
Postby TR Tony » 31 Aug 2012 17:30
Navigate to cpc.co.uk homepage then search for MDM-5 speaker acoustic foam strips.
Inexpensive & looks just like the original when in place. It's a tad narrower in width than original but if you position it carefully you will not notice. I think there are 5 strips in a bag so plenty for the job.
Users browsing this forum: No registered users and 290 guests
