ACG...MOT...
ACG...MOT...
Postby gaz » 18 Aug 2012 06:29
My white one is in for mot at the moment and the guy at the garage say's
the indicators are working but not when the lights are on...
Any suggestions i assume they have attacked the obvious earth points bad connections etc.
My thought is with, it had running lights and side indicators above the bumper corners if these are left with no bulbs in would they cause this.
Over to you guy's
http://mytr7.weebly.com/blackpool-lights-run-2012.html
1981 DHC 2.0 Litre
1980 DHC pedal car
1976 FHC 2.0 Litre
Postby Odd » 18 Aug 2012 07:16
OK, you say "indicators"...
Is this what the rest of us call front parking lights (5W white, yellow in US) or is it the blinkers (21W amber)?
Postby gaz » 18 Aug 2012 07:39
They are the ones that blink to indicate which way we are going...
1981 DHC 2.0 Litre
1980 DHC pedal car
1976 FHC 2.0 Litre
Postby stevie_a » 18 Aug 2012 08:10
<font color="teal"><b>Gaz check the wires of the running lights
look and see if they run down to the indicators
I personaly would not run these as indicators if they are cut the wire and then test
keep them to the side light circuit</b></font id="teal">
HowardB
Postby HowardB » 18 Aug 2012 08:59
I had a similar problem and traced it back to a bad earth connection. I suggest you check the earths carefully
Postby Odd » 18 Aug 2012 10:03
I'd guess you've got grounding problems.
The front blinkers don't share anything with the amber (US type) side lights/indicators.
Well, if you haven't got a DPO wiring problem - then anything is possible...
Users browsing this forum: No registered users and 382 guests
