Mounting speakers
rgsSpider
Mounting speakers
Postby rgsSpider » 14 Aug 2012 21:36
I've got some small box speakers, @9x12x3, that I'd like to mount to the rear firewall. I'd rather it not be a permanent install, don't want to mess up the fw panel if I don't have to. I was thinking industrial strength Velcro, but I'm worried that the heat of the sun (Florida sun that is) may weaken the adhesive on the Velcro and then I'll end up with a sticky mess. These are not real heavy boxes so I'm confident the Velcro would hold them.
Any suggestions?
Randy
Postby FI Spyder » 14 Aug 2012 23:43
Velcro would certainly make them non permanent (last maybe 5 minutes in the wrong part of town.)
How about fashioning a bracket that fits under the seat belt guide and loop over the hump of the rear bulkhead that you could bolt the speakers to similar to what I did with my wind blocker.
Postby DNK » 14 Aug 2012 23:47
Randy- How about making a new rear panel for the speakers
That way you don't ruin mine
"No More Cars For You"
71 TR6- Perpetual Stick a Wedge In It
rgsSpider
Postby rgsSpider » 15 Aug 2012 20:23
I hadn't thought about a bracket. I would prefer the speakers be lower down towards the floor. Something to think about though.
Randy
Postby FI Spyder » 15 Aug 2012 23:12
Mine went up high to get the desired height of the wind blocker (could still be up an inch or two. You could bend them so they go straight down after the panel hump. I got the stainless steel from recyclers for $8 but didn't have enough to make a higher set so used the balance for different application (transmission to lift adapter).
rgsSpider
Postby rgsSpider » 21 Jun 2013 00:57
I finally came up with a solution that I can live with. The speakers came with mounting "tabs" that screwed into the back of the speakers. I attached snaps to the firewall panel and to the mounting tabs on the speakers. So now they are removeable and will hopefully stay in place while driving. Yes I realize the right speaker is upside down, but I wanted them both to point out wards as there is a tweeter on one side.
So now a question. After getting the center console out, and the frame covers on both sides, and all the screws removed, is there a trick to getting that damn panel in and out without contorting it?
Snaps on firewall panel
Back of speaker showing mounting tabs and snaps
Right speaker snapped in place
All finished!
Randy
Postby FI Spyder » 21 Jun 2013 14:25
You need to bend it a bit to get it in. I take it you have no thieves in Florida? [8D]
supercass
Postby supercass » 21 Jun 2013 17:18
[quote]<i>Originally posted by FI Spyder</i>
In my experience there are thieves everywhere! supercass
rgsSpider
Postby rgsSpider » 21 Jun 2013 18:04
I'm not really worried about thieves, they are everywhere and will get what they want no matter how hard it is to get it. I've got a thirty-three year old car, with an am/fm/cassette, with cheap box speakers, I'm not real worried. Plus I don't leave it unattended in questionable places.
Randy
supercass
Postby supercass » 21 Jun 2013 18:31
Can you turn one of the speakers around inside the box so you can mount them symmetrically? supercass
rgsSpider
Postby rgsSpider » 22 Jun 2013 00:30
Nope, can't move them around. Doesn't relly matter, once the panel is installed and the seats are reclined you'll never even see the speakers.
Randy
sheppjr
Postby sheppjr » 28 Dec 2013 16:20
Randy,
How are the box speakers working out on the rear panel in your TR7? Do the speakers sound good? I am thinking of ordering the same ones for my 78 FHC.
Thanks,
Richard
rgsSpider
Postby rgsSpider » 28 Dec 2013 20:08
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sheppjr</i>
Randy,
Thanks,
Richard
They actually sound pretty good! They have stayed put with no problems coming unsnapped or anything like that. Keep in mind, I've got the original head unit in there so it's not producing big fancy sound, but they sound good to me and I can hear them clearly with the top down. They're cheap enough that it was worth the risk to me and I'm real glad I got them. As stated earlier, each speaker is the same so if they will be mounted in plain view you'll have to mount them going the same direction. The open port is on the right side of each speaker and I wanted the sound to be symmetrical more than the appearance.
Randy
Image Image Image http://rgstr7spider.tumblr.com/
sheppjr
Postby sheppjr » 28 Dec 2013 23:36
Randy,
I would mount the speakers the same as yours. I have an old Blaunpunkt Boston SQR49 cassette deck with a Blaupunkt 60 watt amp mounted under the passenger seat. The base response of the 4 inch Blaupunkt speakers in the doors needs improvement. All I need to do is mount the speakers on the panel behind the seats and run the wires to the amp. My other option is to mount a pair of Minimus 7 speakers pointed up behind the seats. How is the base response on the custom auatosound box speakers?
Thanks for your help.
Richard
rgsSpider
Postby rgsSpider » 29 Dec 2013 00:45
I think it's pretty good! It's not going to rattle the car loose, but it makes that old radio sound better than it did when it was new!
Randy
Users browsing this forum: No registered users and 315 guests
