Z-S Carburetor Synchronize Tool-FREE!!!
sjkearney
Postby sjkearney » 07 Aug 2012 23:39
That is just way too cool........
1980 TR7
1997 VW Jetta TDi
2005 Jetta TDi Wagon
Postby dursleyman » 08 Aug 2012 10:30
Wonder if it would work on SU's ?
1980 TR7 Sprint DHC
Postby silverseven » 09 Aug 2012 09:20
this is "sticky" material ......
Bendder
Postby Bendder » 04 Oct 2012 22:33
Mildred
Fantastic.
Ron you definatly need to get this one as a sticky.
Edit
Oops I just realised I just clicked on the sticky, It's been a long day.
1977 TR7 FHC
1978 TR7 FHC
1980 TR7 DHC
1980 Rover SD1 4.0L
john lewis
Postby john lewis » 26 Mar 2013 08:03
hi i am confused u point in first pic. to 2 screws with screwdriver, then u go inside carb to make adjustments, y are u pointing out the 2 screws on side, thanks john
john lewis
Postby john lewis » 26 Mar 2013 08:23
hi me again think i figured it out u make adj.on the 2 screws, u watch the 2 new tools rise together so u can adj. the screws u pointed out at first, i thought u were doing adj. with new tool u make,but new tool is used to watch the rise and fall and adj. are made with the 2 screws am i correct,when i have filters off carbs.i can see that my piston for lack of a better word do not rise together so i think this is proceure i need to do, thanking u in advance, john
john lewis
Postby john lewis » 17 May 2013 09:33
hi started to do this procedure, but before i do i have a ?, how far down do u push straws and what about the dammper oil where will it go when it overflows,thanking u in advance john
Last TR
Postby Last TR » 08 Nov 2013 01:12
I've owned a more durable commercially-made SU tool based on this principle since I bought my first MGA in 1966. I bought another one when I bought my TR6 in 1991. I've always found it much easier to use than any other method. Moss still carries them. Item B. http://www.mossmotors.com/Shop/ViewProd ... rtOrder=20
Instructions: http://www.mossmotors.com/graphics/prod ... 8_INST.pdf
Ken Morton
Anchorage, Alaska
Image Image Image
Users browsing this forum: No registered users and 8 guests
