Jacking points
claypole1360
Jacking points
Postby claypole1360 » 24 Jun 2012 19:11
Hi all,
I am determined to get my 7 in the air and sort out the rear suspension, I have all the trailing arms and new bushes fitted to them so I just have to get my backside into gear and make the most of the long days to swap them over.
Question is,
Where do I put the axle stands at the back?
Where do I jack it up from to insert the axles stands?
Any advice/gems on how to swap the trailing arms and radius arms without losing location of the rear axle?
Thanks, Clayps.
What's that coming over the hill? Is it a monster?
Neil_W
Postby Neil_W » 24 Jun 2012 20:30
I completed the same job on the rear suspension as you are planning plus changing the shock absorbers too.
1.
I jacked the rear end up by placing a good trolley jack under the rear differential housing where there is a flat area ( used a piece of hardwood to save any damage )
2.
With the car up in the air placed a pair of axle stands on the chassis members at the rear - ie behind the bumper & before the rear wheels on each side. If axle stands are too small I used a fence post cut in pieces to raise the axle stand up.
The car was rock solid when I tested it.
3.
Removed the road wheels.
4.
I bought a set of old trailing arms & bars - overhauled them & fitted them so save time ( then sold the old ones ).
Fit one side at a time with new bolts also.Use the trolley jack to raise / lower the axle via the diff casing again.This helped loosen the trailing arms & refit them.
5.
If the shocks are left on that will help keep the axle staight as they will hang on their stops so axle won't go anywhere.
Good luck
Postby PeterTR7V8 » 25 Jun 2012 00:24
Just done this job too. I also jacked it up on the diff but put the stands under the floor just forward of the rear arches. There are pins there to locate scissor jacks.
When you reassemble check the fit of the bolts on the bush sleeves. I found mine were a tad loose on aftermarket poly bushes so I had the sleeves reemed to 12mm & used 12mm bolts. It has eliminated all the play from the trailing arms.
claypole1360
Postby claypole1360 » 25 Jun 2012 06:16
Thanks gents, golden nuggets indeed, can't get that from a Haynes!
Clayps.
Postby busheytrader » 25 Jun 2012 18:56
I did the same as Peter, placing my axle stands beside the pins.
Whilst the axle is out of the way, a good look round for rust with a torch might be worth it. It's better with the tank out of the way but that's something else altogether......
Postby Beans » 25 Jun 2012 19:10
... There are pins there to locate scissor jacks ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I use small wooden blocks (with a hole) over the pins and axle stands ...
claypole1360
Postby claypole1360 » 25 Jun 2012 20:02
Thanks for the picture, that sorts the jacking points. I intend to get the underseal brush out as well, any suggestions for easily obtained products?
Cheers Clayps
Users browsing this forum: No registered users and 282 guests
