Brake master
Brake master
Postby nick » 22 Jun 2012 15:00
I acquired a new brake master cylinder. It has a bleeder port midway down the cylinder. Has anyone installed one of these? At which point in the bleeding sequence would you use this port? Was this an original equipment part in the later cars?
'79 TR7
Postby FI Spyder » 23 Jun 2012 19:55
Bleeder port midway down cylinder? There is a port at the end and midway where the flow of the two pistons goes to the pressure reducing valve where it then separately goes to front and rear brakes. Is this what you are referring to?
Postby nick » 24 Jun 2012 14:20
My old master has three ports. Two with lines connected and one for the caution light. This new master cylinder has one additional port with a bleeder valve. It it just above the warning switch. I have been told this port is used after installation of the master so that you do not have to bleed each wheel.
'79 TR7
Users browsing this forum: No registered users and 301 guests
