pressure plate?
southshoreTR7
pressure plate?
Postby southshoreTR7 » 07 Jun 2012 19:05
Went for a fun drive the other afternoon as as i pulled on to my street the clutch went dead.
What happens is that the clutch will not engage. it is the opposite of sticking to the pressure plate, it feels like it is not even touching the pressure plate. The car stars and runs great, I can shift into any gear but when I push down the clutch pedal nothing happens. the pedal feels a lot lighter than normal (as in takes much less force) with the pedal all the way down you can hear what sounds like the clutch just about to bite and if you hold it then eventually you will smell it. with the pedal all the way up (not being touched) you can shift but get no motion at all.
There are no leaks, the clutch fluid looks good and is not low.
to summarize; the car has not motion (forward or reverse), when you depress the clutch pedal it sounds like it is getting close to touching but that is the opposite of what should be happening when you press the clutch pedal.
I am thinking this is the pressure plate failed but I am not sure. I am looking for any suggestions possible.
1980 Tr7 DHC
Marko
Postby Marko » 07 Jun 2012 20:06
fork was worn trough on its pivot?
Postby busheytrader » 07 Jun 2012 20:10
When the fork wore through the pivot on mine, the pedal went all the way down, then returned all the way back up and went solid.............
Postby saabfast » 07 Jun 2012 20:28
Could be completely shot master or slave seals, or the connecting pipe ballooning with pressure, although that normally does give some operation before it splits.
Saab 9000 2.3 FPT Auto
Saab 2.3 LPT Auto
Stag76
Postby Stag76 » 08 Jun 2012 06:06
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> with the pedal all the way up (not being touched) you can shift but get no motion at all.
The Hydraulic System dis-engages the clutch...if the pedal is up and there is no motion a broken pressure plate is usually the cause.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
willywonka
Postby willywonka » 08 Jun 2012 08:18
Possibly the slave cylinder has siezed in the outward position as well.
It happened to mine recently and it was just a case of removing it, freeing up the piston and refitting and rebleeding.
Job done.
All the Gear, no idea
southshoreTR7
Postby southshoreTR7 » 08 Jun 2012 15:37
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stag76</i>
[quote] with the pedal all the way up (not being touched) you can shift but get no motion at all.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
This is what I am thinking and dreading.
thank you all for the responses and help.
1980 Tr7 DHC
Users browsing this forum: No registered users and 312 guests
