LT77 ID?
V8Wedgehead
LT77 ID?
Postby V8Wedgehead » 03 Jun 2012 00:47
I just cleaned up a transmission that was out of a parts car TR7. The tranny was NOS replacement from a JRT/Jaguar dealer in 1986 and was used for 10,000 miles and the car was forced off the road in 1988 by an accident. The ID number is 27A0017738D and it has on the left side of the case the BL sirl without the "L". I think it is a 1981 and newer LT77 with the taller 5th gear? Any one know more about the ID numbers?
Michael
1980 RALLY TR8 FHC #0020
Postby john 215 » 03 Jun 2012 07:10
Hi Michael,
The ID list i have is as follows -
Gear box identification
the identification marks can be found on an oval lug near the base of the box
G16A SD1 2000 (Could be 4 speed)
G17A SD1 2300/2600 5 speed
G19A SD1 3500 SE/VP 5 speed
G22A SD1 3500 Police spec 5 speed
G23A SD1 2600 Police spec 5 speed
G26A SD1 2400 Diesel 5 speed
G27A SD1 2000 Later model 5 speed
G28A SD1 Vitesse 5 speed
G30A Sherpa Range
Not sure about your having the higher 5th gear, ( 37 / 19 ) , maybe compare with a early box. If you have another box ( early one ) turn the input shaft when in 5th and see what the outshaft turns in relation.
These guys may be able to tell you more, what they dont know about these boxes is'nt worth knowing
http://www.ashcroft-transmissions.co.uk/index.php
1976 Speke FHC Beauty
Users browsing this forum: No registered users and 248 guests
