Carmine Red Paint
ColoradoTR8
Carmine Red Paint
Postby ColoradoTR8 » 24 May 2012 11:47
Hey folks,
Does anyone have a good modern paint code for Carmine Red? I've seen other supposed correct numbers that came out more purple. Looking to avoid that.
<b><i>Shawn</i></b>
Postby windy one » 24 May 2012 14:54
If your car is the original color (from factory) most if not all body shops/paint suppliers should have a reader that 'reads' the paint color and provides a very good match/close match.
My local body shop did such on my previous TR8. It was originally gold but someone repainted the car green. I only needed to have one door sprayed, so he used his paint reader to all but exactly match the color. It was so close, only I could see the difference. [8D]
Peter Nuss
Postby Peter Nuss » 24 May 2012 17:38
Sorry I don't have the code. I painted my car twice with dupont codes and never got the color right. Would you mind posting the code if you successfully get it right?
TR8
Postby FI Spyder » 24 May 2012 22:11
Paint fades with time, especially the reds. If you're trying to match existing paint a scanner/reader is your best way to go. If you're going for a total paint job and just want to get close to original and their computer doesn't have Triumph, check under British Leyland or Jaguar as it may be listed under those sections. When I went for Poseidon Green it was listed under Jaguar.
Postby DNK » 24 May 2012 23:26
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by windy one</i>
Mine was repainted too and also green.
That will work unless metal flake is added.
Could not get the machine to get thru the flake to the color on mine
"No More Cars For You"
71 TR6- Perpetual remodel
jtmco
Postby jtmco » 25 May 2012 11:24
Check out the Auto Color Library and look for a 1973 Triumph paint chip:
http://www.tcpglobal.com/autocolorlibrary/default.aspx
They can mix different kinds of paint.
Good luck.
Jim
ColoradoTR8
Postby ColoradoTR8 » 27 May 2012 13:01
Found this.
Dupont code 43019. Mixing formula is below.
IngrdCd Description gram (abs.) gram (cum.)
AM55 LIGHT RED 193.5 193.5
AM64 MAGENTA 112.4 305.9
AM7 BLACK L.S. 38.3 344.1
AM1 WHITE H.S. 12.9 357.1
AM86 OPAQUE RED 1.7 358.8
XB155 M.S. BINDER 387.8 746.6
XB165 M.S. BINDER 200.1 946.7
Will have a test panel shot before I say yes though.
<b><i>Shawn</i></b>
Users browsing this forum: No registered users and 243 guests
