How can I stop a Gearbox oil leak ?
farrikt
Postby farrikt » 10 Apr 2012 18:35
Anyone had a good experience using oil leak additives that allegedly stop or reduce oil leaks ? I have an annoying oil leak that seems to be coming from the gearbox, nothing major so just want to slow it down until I can take care of it. Thanks for any suggestions.
Kevin
Postby Beans » 10 Apr 2012 20:27
Were's the leak?
Always better to do it properly, so change the seal.
<b>[url="http://www.tr7beans.blogspot.com/"]<u><b><font size="3"><font color="red">My Weblog</font id="red"></font id="size3"></b></u>[/url]</b></i></center>
Postby nick » 11 Apr 2012 16:49
Never heard of an gearbox additive. Some have reported success with an engine additive, although I am not a fan of using these products. Best to fix the leak properly.
Where exactly is the oil leaking? Are you sure it is the gearbox? Best to do a thorough cleaning and then run it to see where the oil is coming out. Report back and I'm sure we can help out.
'79 TR7
Postby FI Spyder » 11 Apr 2012 18:39
A common leaking point is the old O ring seals on the oil pump and the oil transfer cover where it is then blown back to the gearbox at speed. Best attend oil leaks when you have to change the clutch which is where I'm at now. There is a front oil seal, rear oil seal (can be changed without taking out trans). Another spot is the rear engine seal and the shifter rod O ring and the speedometer O ring and oil seal. The rubber gets hard with age and heat and shrinks a little as well. It looks as if my transmission has been opened before as it doesn't have gaskets but gasket goo which I'm presuming they used rather than waiting for a gasket order to come in.
Not a fan of stop leak additives (trans or rad). I'd rather put up with it. Read this.
http://www.epinions.com/auto-review-51D1-9E04C92-397E2532-prod4?sb=1
Postby Beans » 11 Apr 2012 19:24
... the shifter rod O ring ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Not the most simple solution, but this is how I have tackled this problem on the gearbox I am currently rebuilding ...
Postby nick » 12 Apr 2012 18:28
Beans,
When I had my gearbox out I had good luck with replacing the shifter "O" ring. No leak after about 1,000 miles.
'79 TR7
Postby Beans » 12 Apr 2012 22:38
The original oil o-ring will also be used, this is just an extra seal.
Bonus is that it not only seals against oil leaking out but also against dirt getting trapped between selector shaft and casing.
And to be honest 1000 miles isn't that much for a seal to last.
I covered 10.000 km with my DHC in 15 months before the (paint) troubles started.
So I want a better life expectancy from my oil seals [:D]
Postby DNK » 12 Apr 2012 22:44
Beans, you did document how and with what tools you used ,didn't you? [?]
"No More Cars For You"
71 TR6- Perpetual remodel
Users browsing this forum: No registered users and 357 guests
