making (light) work of it....
Postby gaz » 24 Mar 2012 18:10
Whats the easiest method of taking lights out for painting
undoing bolts inside lamp pod or taking out the pod and motor assembly in one
http://mytr7.weebly.com/
1981 DHC 2.0 Litre
1980 DHC pedal car
1976 FHC 2.0 Litre
Postby Beans » 24 Mar 2012 18:19
When preparing the DHC for the repaint I just removed the pods
and left the lifting mechanism and wiring in place ...
Take care not to damage the rubber grommet/plug that seals the hole where the wiring enters the headlamp bowl.
<b>[url="http://www.tr7beans.blogspot.com/"]<u><b><font size="3"><font color="red">My Weblog</font id="red"></font id="size3"></b></u>[/url]</b></i></center>
Postby DNK » 24 Mar 2012 20:46
Boy, those threaded parts look really fragile
"No More Cars For You"
71 TR6- Perpetual remodel
Postby gaz » 25 Mar 2012 20:23
Thanks beans i guessed that may be the best route
1981 DHC 2.0 Litre
1980 DHC pedal car
1976 FHC 2.0 Litre
Postby Beans » 28 Mar 2012 09:58
And you have to remove the three connectors from the plastic blocks
that goes to the headlamp unit ...
Otherwise you can't remove the loom from the headlamp bowl
Some very fine screw drivers will make light work of removing them
Users browsing this forum: No registered users and 316 guests
