Wheel cylinders
mb4tim
Wheel cylinders
Postby mb4tim » 12 Mar 2012 23:14
So, how bad of a job is replacing the rear wheel cylinders? I did a rebuild kit a few years back,but, they still seep a little fluid.
Will I dread this job? Special tools? Clay, is there a special badge for this job? LOL
-Tim
darrellw
Postby darrellw » 12 Mar 2012 23:48
If you've ever done drum brakes, it isn't really any different. The trickiest part is getting the e-clip back on. Clay has a good write-up, and a trick to get that clip back on:
http://web.me.com/jclaythompson/Site/Rear_Brakes.html
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby john 215 » 13 Mar 2012 04:48
Easy job, just follow my learned freinds JClay excellent giude.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The trickiest part is getting the e-clip back on<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Use this and no longer a problem [8D]
Also how about 4 speed cylinders, give a more balanced braking
1976 Speke FHC Beauty
mb4tim
Postby mb4tim » 13 Mar 2012 09:54
I like the e-clip tool. Where do I find that?
I've done the brakes before, it was actually the first job I did sine the rear brakes were seized up.
Thanks for the help. I was hoping not to take apart the whole assembly to replace the cylinders. Wish me luck wth that.
-Tim
Postby FI Spyder » 13 Mar 2012 14:02
I use this tool I bought for $5.95 at Liquidation World. Took me less than a minute. You can use it for lots of other things as well. It has long handles about 14" I'd say, for precise control of the jaws. You can find it at any local tool shop, but probably a little more money.
mb4tim
Postby mb4tim » 13 Mar 2012 15:38
I can also find it in my tool box, smart@$$...LOL [:o)]
-Tim
Neil_W
Postby Neil_W » 14 Mar 2012 04:45
[quote]<i>Originally posted by john 215</i>
[quote]The trickiest part is getting the e-clip back on<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Not at home at present so do you know the outer diameter of the conical end piece & thread of tightening bolt ?
Will see if I can knock one up in the Workshop - was a swine when I did my Brake Cylinder last year & e-clip is I feel too bent for my liking so needs a new one.
Tool will save my fingers / temper
Postby john 215 » 14 Mar 2012 04:53
Hi Neil,
PM me your address later and will do you a drawing with measurements, not clever enough to put owt on here [:o)]
Postby Workshop Help » 14 Mar 2012 10:37
Now, Boys! In fact the all around best way to fix your rear brakes is to send the brake cylinders off to places like White Post Restorations or Apple Hydraulics or some such, and have the bores lined with either a brass or stainless steel sleeve. This will eliminate the corrosion factor present with the standard iron bore.
On to the second choice; install a new standard iron bore wheel cylinder.
Finally, the old El-Cheapo remedy is to hone the cylinders on the car and fit a new rubber seal kit.
So, my dear Hot-Shot, what's it agonna be? The more you pay, the better your option.
Postby jclay (RIP 2018) » 14 Mar 2012 11:25
mb4tim
Postby mb4tim » 14 Mar 2012 11:41
ohhh, I already did that one...LOL
-Tim
Postby Hasbeen » 14 Mar 2012 13:46
Any one doing their rear wheel cylinders should pull up the old posts of our dear departed Ally Hickman, detailing her frustration with those clips. She had me laughing out loud, with here, not at her. She was a peach.
Neil_W
Postby Neil_W » 16 Mar 2012 04:33
Hi Neil,
John,
Do I just send you an e-mail ie PM by clicking on your Login name & send mail ?
Anyway sent you a message that way !
Neil
Postby john 215 » 16 Mar 2012 04:43
Hi Neil,
Got it will sort something out over the weekend
Neil_W
Postby Neil_W » 03 Apr 2012 03:12
A tool for those crafty clips - must say Johns one looks simpler
http://www.ebay.co.uk/itm/140609685156? ... 1423.l2649
Users browsing this forum: psjmay1960 and 223 guests
