Repainting mirrors
rgsSpider
Repainting mirrors
Postby rgsSpider » 17 Feb 2012 22:41
I've finally got a complete set of original mirrors and all mounting hardware, thanks to S&S! I'm getting all the old paint sanded off, down to the metal. I plan to paint them semi-gloss black, I'm assuming that's the original color. My question is, do I need to prime them first, or is there a one-step paint I can use. Just want to do it right. Should I look into getting them powder coated?
Thanks
Randy
Postby FI Spyder » 17 Feb 2012 23:52
I painted mine with trim paint. It's self etching so doesn't need a primer. It's satin (semi gloss) like most black trim. It stands up well. I also painted my windshield lower trim piece, quarter window frames, with it as well (in 2006/7) Still looks like new. Powder coating would no doubt be better but more expensive. I think I used Pro Form brand.
rgsSpider
Postby rgsSpider » 18 Feb 2012 00:09
Thanks for the tip. I'm not able to find where to purchase Pro Form paint, I'll have to check my local auto parts store.
Randy
Postby silverseven » 18 Feb 2012 01:54
I used SEM Euroblack , using the similar process as Spyder
Light scuff with a scotchbrite pad, wash down with some panel prep, and couple of coats of spraybomb.
http://semproducts.com/product-catalog/specialty-products/trim-paint/euro-trim-black/
Image Image Image
Postby john 215 » 18 Feb 2012 05:21
Took mine back too bare metal, etched primered and then satin black spray.
Cheers John.
1976 Speke FHC Beauty
Postby gaz » 18 Feb 2012 06:26
Mine were done the same way as Johns
although my car is going into the body shop next month and whilst its there i might have all the black bits powder coated depending on cost....
http://mytr7.weebly.com/
Roy Hankins
Postby Roy Hankins » 18 Feb 2012 06:47
I wouldn't recommend blasting and powder coating the mirrors, as it's
to fierce. I had some done and the mirror back was full of ripples.
Roy
Postby Beans » 18 Feb 2012 12:48
I had mine powder coated as it was the cheapest and easiest option.
But indeed the blasting has to be done very carefully to avoid damage.
Postby DNK » 18 Feb 2012 15:09
As the last 2 replies above.
I agree
"No More Cars For You"
71 TR6- Perpetual remodel
rgsSpider
Postby rgsSpider » 18 Feb 2012 17:04
Thanks for all the tips! I've already gotten most of the parts sanded down to bare metal. Probably go with the self etching paint, I'll let you know how it goes.
Randy
rgsSpider
Postby rgsSpider » 24 Feb 2012 01:09
All done! They look great too! Thanks for all the tips. I ended up using SEM self etching primer and trim paint.
Randy
Postby gaz » 24 Feb 2012 05:22
You can have the best paint on your car body in the world but if your blacks arn't right then your car ain't right......
Nice job
elsberry
Postby elsberry » 24 Feb 2012 21:31
I totally agree. I'm in the midst of a complete restoration from a stripped shell all the way back up to original, and I have a quart of the same SEM paint sitting in my paint cabinet waiting to paint all the trim with it. It is by far the easiest way to get a good match on for the OEM trim black.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by gaz</i>
Nice job
<b>Dave Elsberry</b>
<b>Secretary & Editor Triumph Wedge Owners Association</b>
rgsSpider
Postby rgsSpider » 25 Feb 2012 01:53
Thanks guys!
Randy
Postby DNK » 25 Feb 2012 03:27
Here all this time I figured black
Users browsing this forum: No registered users and 149 guests
