Wheel Offset
Wheel Offset
Postby REPLIC8 » 02 Feb 2012 17:22
I'm looking to upgrade my wheels from standard alloys with 205/60/13 tyres to a set of Minilites 15 x 6 with 205/50/15 tyres. The rolling radius should be pretty much spot on but I'm not 100% sure about the offset required with the wider rims.I think the standard alloys have a 25mm offset, as the new tyres will be the same width as the old ones a 25mm offset on the new wheels should keep the tyres in the same place but the rim would poke out slightly more on both sides, or do I need slightly less offset, say 20mm, to keep the inside edge of the wheel in the same place, but then risking catching the outside edge on full lock?
What offset do the MGF/Montego alloys have as these seem to be a straight swap for a TR. Need to get this right before I order as it will be an expensive mistake if they're wrong.
darrellw
Postby darrellw » 02 Feb 2012 17:42
I believe you should use the same offset, so that the centerline of the tire is in the same position relative to the suspension's geometry.
I have 15x7 wheels on my car, 25mm offset, same size tires that you are looking at, and they fit fine. The fronts are pretty close to the strut, but no signs of interference.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Users browsing this forum: No registered users and 310 guests
