clutch slave cylinder mount bolt info
catmanboo
Postby catmanboo » 29 Jan 2012 04:28
a mundane question: what's the length & thread pitch (SAE or metric?)of the clutch slave cylinder bolts? I need to restore threaded holes in bell housing; p.o. buggered them badly, not sure the ones I removed were correct. thanks-Jerry
Neil_W
Postby Neil_W » 29 Jan 2012 07:52
From spec sheet think it is metric 8 mm - length would I expect be the length of the securing flange of the slave cylinder + width of Gearbox flange minus a few mm's.
You can download a Works Manual from www.triumph-cars.co.uk under section PDF's
staningrimsby
Postby staningrimsby » 29 Jan 2012 08:00
Cheers for that Neil,
I found that a really interesting web site, even nabbed me a copy of the manuals as well [:)].
1980 2.0 16v DHC - Polly.
Dave Dyer
Postby Dave Dyer » 29 Jan 2012 09:03
Hi Jerry,
What I did was to drill and tap the holes 10mm and also drilled out the holes in the clutch slave cylinder to match.
I found the thread was too poor to retap the hole the original size.
And didn't want to take the chance of it failing miles away from home!
Cheers. Dave
Postby Beans » 29 Jan 2012 09:36
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Dyer</i>
... drill and tap the holes 10mm ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Better to use an M8 thread repair from the like of Helicoil or Recoil ...
Postby Odd » 29 Jan 2012 11:02
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> it is metric 8 mm - length would I expect be the length of the securing flange of the slave cylinder
+ width of Gearbox flange minus a few mm's. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> OK, the securing flange of the slave cylinder I have in hand is 10mm thick.
Anyone have a clutch housing on the bench/shelf to take that measure from?
To this should be added:
the thickness of that sheet metal ("rear adaptor plate") fitted to the engine block and
the thickness of the washer(s) used.
Then you can decide on a suitable length screw for this application...
And as always I recommend stainless part threaded screws (with an aluminium based
antiseize paste) so you can easily take it apart twenty plus years from now... [:)]
Postby john 215 » 29 Jan 2012 11:13
I always drill the blind hole deeper and tap the tread down as far as poss and longer bolts.
1976 Speke FHC Beauty
Dave Dyer
Postby Dave Dyer » 29 Jan 2012 11:33
Better to use an M8 thread repair from the like of Helicoil or Recoil ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Hi Beans,
That would probably be a better option, I always thought it would have to be done at a machine shop, I didn't realise there was a DIY version. Might be worth looking out for a set.
Cheers, Dave
catmanboo
Postby catmanboo » 29 Jan 2012 17:23
many thanks, guys, especially Neil for spec sheet posting. as there shall be no more threaded bare aluminum holes anywhere on either the head or bell-housing, I want to get it right the first time. as is well known, threading anything into bare aluminum is a crap-shoot, eventually you'll have problems. found that out years ago on my old Harley shovelhead.there's now a threaded insert seized onto the front spark plug, & studs where bolts used to go! gonna drop the sub-frame today, blast & POR-15 it, & photo-document the engine bay prior to stripping it for repaint...Jerry
Postby DNK » 29 Jan 2012 17:36
Jerry, what part of US you in?
"No More Cars For You"
71 TR6- Perpetual remodel
Postby jclay (RIP 2018) » 29 Jan 2012 20:46
I keep telling you guy to buy two bolts about 1/2" longer to start the slave cylinder with, then remove one and replace it with the original, then do the other.
No more stripped out holes.
Does anyone listen?
Postby Beans » 29 Jan 2012 22:40
... Does anyone listen? ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Nope, and don't read either [:p]
Postby DNK » 30 Jan 2012 01:48
[quote]<i>Originally posted by jclay</i>
<font size="3">Nope, and don't read either</font id="size3"> [:p]
Rebel!
Postby FI Spyder » 30 Jan 2012 15:12
Does anyone listen?
I do but when I overhauled my slave cylinder I didn't have any problem putting it back on. When I do my clutch this winter I may and will be paying attention to it.
Postby silverseven » 31 Jan 2012 01:21
...... when I overhauled my slave cylinder I didn't have any problem putting it back on.....
me neither .....and I had mine on and off again a couple of times!
Image Image Image
Users browsing this forum: No registered users and 358 guests
