Good Evening Lads and Lassies!
edforrest
Postby edforrest » 27 Jan 2012 00:01
Anyone have a line on front wheel studs for new rotors?
1.) Are both thread patterns right or left?
2.) Is one left AND the other right?
3.) What are the chances of successfulllllly removing existing studs from old rotors?
Thanks...ed
edd
Jolyon39
Postby Jolyon39 » 27 Jan 2012 00:57
Hi Ed,
I am not sure what you mean here. The brake rotors bolt to the hubs and the hubs have studs for the wheel nuts. Rotors are easy to remove because they use bolts.
Can you put up a pic?
Jolyon
edforrest
Postby edforrest » 29 Jan 2012 18:06
The replacement rotors do not have studs! I am looking to replace the studs in the rotors.
edd
staningrimsby
Postby staningrimsby » 29 Jan 2012 18:17
Hi Edd,
If I have understood you right they are the same stud for both sides, but I dont think you can buy them new anymore [:(].
Is this what your looking for;
http://www.rimmerbros.co.uk/Item--i-UKC2213
1980 2.0 16v DHC - Polly.
Postby busheytrader » 29 Jan 2012 18:59
Are we talking the same language either side of the pond?
You say Tomato I say Tomato. Potato / Potato
The rotor (brake disc) is bolted to the hub UKC4817
http://www.rimmerbros.co.uk/Item--i-GRID006193
Have a look round the Rimmer Bros website. It's very informative.
Postby jclay (RIP 2018) » 29 Jan 2012 20:59
IF you can find them, there are $25 a pop! (Like, each!) Use the old ones and press them out and press them back in. They are all exactly the same. I removed my and put them in new hubs when I did the big bearing change out.
New, rotors? The rotors bolt on from the front of the hubs. Once you unbolt them from the front,just pull off the hubs and the new one just slide off/on.
Users browsing this forum: No registered users and 327 guests
