Fuel Tank Filler
cozyheatdave
Fuel Tank Filler
Postby cozyheatdave » 07 Jan 2012 18:36
On the fuel tank filler there is a black rubber hose from the top cap assembly to the tank. But, inside the rubber hose is a steel fuel pipe.
What is the purpose of the inside pipe? Why not just the rubber hose from the cap assembly to the tank?
The reason I ask is that I'm replacing my cap assembly with a custom system and I'm looking for a hose to fit. Can I use the original hose without the steel pipe?
I couldn't repair my brakes, so I made my horn louder.
[img=left]http://i1239.photobucket.com/albums/ff504/tikvahmarketing/Forum_pic.jpg?t=1324940124[/img=left]
supercass
Postby supercass » 07 Jan 2012 18:47
Think the steel pipe may be part of the anti syphon device. Regards
Postby FI Spyder » 07 Jan 2012 21:25
The gas goes through the steel pipe into the gas tank with there being no sealed connection to it. The rubber hose basically acts as a flexible seal to seal in vapours. I would have some reservations relying on just the rubber hose although it would work for a while but rubber deteriorates and would eventually leak I would think. A neoprene hose with steel spring reinforcement would be better.
http://www.gates.com/brochure.cfm?brochure=5076&location_id=5246
Postby busheytrader » 08 Jan 2012 21:27
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by supercass</i>
.........and also to do with safety in the event of a crash. IIRC I read that the tank and its contects were designed to remain intact in a serious shunt. It enables the rear deck to move about but not rupture the filler pipe or tank.
Postby john 215 » 08 Jan 2012 21:36
The UK spec pipe also has a small pipe for brether.
I guess the US spec will be different as we dont have such things as carbon cannisters etc
1976 Speke FHC Beauty
Postby FI Spyder » 08 Jan 2012 23:16
That's right. The fuel tank is vented to atmosphere (the gas cap is vented).
In N/A they didn't want these vapours into the air as the vapours and sunlight produced smog (on a clear day you couldn't see downtown LA). So they had a "sealed" system. A small metal tube in gas tank runs to outside where by a rubber hose goes to fuel separator which then goes to rubber hose to metal tube to engine bay to charcoal canister and then to intake. Crankcase vapours go to carbon canister as well which goes to intake. The gas cap is sealed. So by virtue of the intake vacuum the entire system is under vacuum (slight) not enough to prevent a carb fuel pump to pump gas to carbs. That is why if your system is working correctly (no leaks) there is a slight whoosh of air as you open the gas cap as air rushes in. If the system leaks you won't achieve the maximum vacuum in intake. The system doesn't cause any power loss as canister(s) don't weigh that much. They do take up room in the engine bay though.
Also to eliminate gas vapours in the States when you fill up you also have a spring loaded cover on the fill nozzle that has to be compressed before the fuel flow can be started. Here in Canada we just have a cover that kind of stops the vapours from escaping (doesn't really just a concession to the environmentalists who don't know any better).
Postby DNK » 09 Jan 2012 02:32
Still can't see down town LA on a clear day.
Guess it ain't working
"No More Cars For You"
71 TR6- Perpetual remodel
Postby FI Spyder » 09 Jan 2012 14:12
You could when I went through in June but maybe it was just one of those days.[8D]
Postby Beans » 09 Jan 2012 15:50
... You could when I went through in June ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
So you clearly spoilt it [:p]
mb4tim
Postby mb4tim » 09 Jan 2012 17:38
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by FI Spyder</i> I would have some reservations relying on just the rubber hose although it would work for a while but rubber deteriorates and would eventually leak I would think. A neoprene hose with steel spring reinforcement would be better.
The MGB had an opening through the trunk floor that a large rubber hose connect it to the filler piece. No worries there.
-Tim
jbsjim
Postby jbsjim » 09 Jan 2012 17:47
Tim,
My 63 MGB has a metal pipe in exactly the same shape as your rubber one with short rubber connections on both ends. I think it's one of the clunkier design decisions made by the folks at Abingdon.
Jim
Postby DNK » 09 Jan 2012 21:52
Oh, I thought you meant from any where.
mb4tim
Postby mb4tim » 10 Jan 2012 12:26
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jbsjim</i>
Tim,
Mine has the same, but I've seen the all rubber ones, that's why I posted this pic.
-Tim
Postby FI Spyder » 10 Jan 2012 16:04
Seems rather exposed in the trunk, exposed to things in the trunk ramming into it but then I don't suppose to many MGB owners use their cars to haul cement patio blocks or packages of hardwood flooring like I do in my TR7.
jbsjim
Postby jbsjim » 10 Jan 2012 16:41
FI, back when I was a lad I reroofed my brother's garage in Berkeley. My 67 B hauled all of the roofing materials from nearby Oakland. Talk about a low rider!
Jim
Users browsing this forum: No registered users and 176 guests
