Decal placement
whitenviro
Decal placement
Postby whitenviro » 17 Dec 2011 18:14
My car is back from the shop and I need to replace a number of the decals. There is a nice little write-up from Martin Rothman in the Google Documents section about placement, but it doesn't have measurements for where the front laurel wreath goes.
It's a 1980 with the large wreath; can anyone tell me a measurement down from the bonnet edge to the top of the wreath?
Also, the shop stripped the inside of the bonnet for painting, so I lost any decals there. I know there was a large yellow one with engine specs located near the upper right corner. Would there have been any other labels on the inside of the bonnet? I don't have any old pics that show the whole thing. Same for door edges, near the VIN plate. I'm pretty sure there was a sticker there, but don't have a picture. Was it the one about Catalyst air emissions? A photo or two would help!
[/img]
HowardB
Postby HowardB » 17 Dec 2011 19:59
There was an article in the TR Drivers Club mag a few years ago - probably 2008 - which gave the exact locations for all the external logos.
Postby Chris Turner » 17 Dec 2011 20:01
The original article was in Issue 3 2003.
www.triumphtrs.co.uk
THE Coca Cola car
The C+C Conversions rally car
TR7V8 rally car
whitenviro
Postby whitenviro » 17 Dec 2011 22:40
Any idea how I can get access to that article? Is there an on-line reference for it?
[/img]
Postby DNK » 18 Dec 2011 00:27
"No More Cars For You"
71 TR6- Perpetual remodel
Postby silverseven » 18 Dec 2011 02:03
here's the best pic I have of my '78's nosecone that you could use for reference.....sorry no measurements though.
Image ImageImage
HowardB
Postby HowardB » 18 Dec 2011 17:49
if you go to the http://www.trdrivers.com/ web site and contact the editor of their club magazine you might be lucky :)
Postby silverseven » 19 Dec 2011 00:01
here's the inside of the 1982's hood (THE 1978's hood insides were flat black from the PO)
nb - note the lack of quality control found even on a Soliull car....
(TR8 specs on a TR7 [B)])
Image ImageImage
frankman
Postby frankman » 19 Dec 2011 10:50
... it's TR8 but..
Front valance TR8 decal -
Top edge of the decal is X below the hood/valance joint:
[The decal is centred horizontally on the valance.]
6" / 152.40mm 5-5/8" / 142,88mm
Boot lid TRIUMPH decal -
lower edge of the decal is X above the bottom edge of the trunk lid:
1-11/16" / 42.86mm 1-11/16" / 42,86mm [Here they match.]
The lower left corner of the horizontal part of the T is X from
the left edge of the trunk lid:
1-3/4" / 44.45mm 1-5/8" / 41,28mm
Boot lid TR8 decal -
1-1/8" / 28.58mm 1-5/16" / 33,34mm
The rightmost edge of the upper half of the 8 is X from the edge
of the lid:
2" / 50,80mm 2" / 50,80mm [Here they match.]
_RIGHT_ [or Starboard] fender decals -
Find a point along the swage line to the right of the left (door
hinge side) edge of the fender:
5-7/8" / 149.23mm 6-1/4" / 158,75mm
The lower left corner of the L in the "LITRE" decal is X above
this point on the swage line:
3-5/8" / 92.08mm 2-7/16" / 61,91mm
Since the "3.5" and "LITRE" decals come on the same backing
piece, this puts the left edge of the "3.5" X from the left
edge of the fender:
2-3/4" / 69.85mm 3" / 76,20mm
The bottom edge of "TRIUMPH" in the wreath decal is X above
the top edge of the "LITRE" decal:
2" / 50.80mm 1-3/8" / 34,93mm
the leftmost edge of the wreath decal is X from the left edge
of the fender.
4-3/8" / 111.13mm 4-15/16" / 125,41mm
_LEFT_ [or Port side] fender decals -
Find a point along the swage line to the left of the right (door
hinge side) edge of the fender. [NO DATA from Tim here...]
--- / --- 6-7/8" / 174,63mm
this point.
--- / --- 2-1/2" / 63,50mm
piece, this puts the left edge of the "3.5" X from the right
edge of the fender:
--- / --- 9-1/2" / 241,30mm
--- / --- 1-3/8" / 34,93mm
the leftmost edge of the wreath decal is X from the right edge
of the fender:
--- / --- 7-5/8" / 193,68mm
All measurements were made using horizontal and vertical lines from
curved panel edges, so accuracy is a little limited. But not as limi-
ted as the differences of measurements show. PLEASE! Do measure at
least two or three times before applying your decals, and as always,
your exact placements may vary from the ones found on mine and Tim's
cars...
http://www.team.net/archive/triumphs/2001-11/msg00805.html
End Quoted material-----
Hello from Switzerland
Frank
whitenviro
Postby whitenviro » 19 Dec 2011 16:30
Thank you all!
It looks like DNK has the same yellow US engine specs sticker under the bonnet, and that should be all I need under there, since I don't have air conditioning. The black stickers like Silverseven's must be Canadian.
The TR8 dimensions seem to be different than the TR7, even for the pieces that I would think are the same (like the TRIUMPH on the left of the boot lid; it is further to the right than the measurements in Martin Rothman's summary).
I contacted Valerie McMillan of the TR Driver magazine, who told me she has a pamphlet made up from the 2003 articles with all of the dimensions, taken directly from a couple original cars (including hers). She is sending it to me. I will scan it and put it in the Google Documents summary. But I would assume it will be UK specs and won't be exactly the same for US. I still don't know what decal went on the door near the VIN number plate, but I assume it was the air emissions sticker for 1980 US Federal vehicles.
[/img]
Postby silverseven » 21 Dec 2011 01:37
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by whitenviro</i>
-The black stickers like Silverseven's must be Canadian.
- I still don't know what decal went on the door near the VIN number plate, but I assume it was the air emissions sticker for 1980 US Federal vehicles.
You are probably right on the black CDN labels , especially considering they are bi-lingual. Come to think of it, though I'm not certain I've ever seen a American wedge either.........
Again maybe not relevant to your American car, but my original 82 car has no other info on the inside door jam other than he metal vin number + data plate. The 78 was repainted by the PO, but also only had the number plate inside the door
Image ImageImage
Users browsing this forum: No registered users and 382 guests
