air passage thru bulkhead/firewall
catmanboo
Postby catmanboo » 14 Dec 2011 01:23
'tis the season for snow, which means the 2-wheel Triumph gets a SHORT break. I'm getting ready to return to the tr7 renovation, a burning question ...what's supposed to be in place in or over the fresh air passage thru the firewall (bulkhead)? my car had a piece of window-screen duct-taped in place to keep leaves, bugs &/or critters & birds out of the cabin. I've never been able to find any ref to a cabin air filter, which ought to be there- nothing in any parts catalog I've seen, or referred to in the Haynes manual.any suggestions welcomed- thanks!
Postby Odd » 14 Dec 2011 09:31
Nothing there, just a big black hole. Cabin air filters were not invented yet...
Postby silverseven » 14 Dec 2011 10:19
Nothing there, just a big black hole. Cabin filters <font color="red"> (/service- department profit generating devices )</font id="red"> were not invented yet...
Post corrected .......
Image ImageImage
Postby john 215 » 14 Dec 2011 10:42
Hi Ron,
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">quote:
Nothing there, just a big black hole. Cabin filters (/service- department profit generating devices ) were not invented yet...
Totaly spot on, [:p] however eventually they block up with crud, leaves etc and then no air good or bad can get in the car !!!
1976 Speke FHC Beauty
DutchTriumph
Postby DutchTriumph » 14 Dec 2011 14:25
When I put the heater back in the car, I've placed a piece of fine mesh (normally used to keep the insects out) between the bulkhead and the heater. Works fine to keep the leaves out.
Peter
Postby busheytrader » 14 Dec 2011 18:12
Agreed.
These so called pollen filters can be more expensive than the engine's air filter.
Postby Hasbeen » 15 Dec 2011 02:16
Just drive faster, [}:)] then the bugs & things won't be able to catch you up to get in! [:D]
Postby silverseven » 15 Dec 2011 10:16
Agreed.
Yes, I work for a GM shop, and they can be more than double the price of a standard air-filtre
Image ImageImage
catmanboo
Postby catmanboo » 19 Dec 2011 02:54
all that being said, I may make a frame to wrap something around. I've an almost endless supply of old t-shirts, to be backed up by a piece of fiberglass window screen, if nothing else. too buggy in these parts 6 months of the year...[:D]
Users browsing this forum: No registered users and 175 guests
