Jack placement in boot
rgsSpider
Postby rgsSpider » 11 Dec 2011 05:43
I am the proud new owner of an original jack, jack turning rod, lug wrench, and the infamous blue bag! Now, how does all that fit in the trunk/boot? By that I mean, originally, where was it all placed? And did the spare face up or down?
Randy
Postby TR Tony » 11 Dec 2011 08:26
Well Randy. AFAIK the spare sat face down with a rubber strap across to secure it. The jack itself sits against the bulkhead partly resting on the tyre, with the jacking point (piece with the hole) facing rearwards - there should be a separate rubber strap to secure it.
The blur bag holds the rest of the tools & sits across the tyre within the wheel well recess, then your board should fit over all this then your mat with the press studs to hold it all in place.
Postby FI Spyder » 11 Dec 2011 15:06
This is how I found/have mine. Fiberboard on top, then vinyl mat. Can't recall if blue bag is on top of tire or underneath.
rgsSpider
Postby rgsSpider » 11 Dec 2011 23:28
Great, that's pretty much what I thought but wanted to check anyway. Thanks guys!
Randy
Postby Workshop Help » 11 Dec 2011 23:54
Don't forget there is supposed to be a small rubber pad between the jack and the metal bulkhead to keep the jack from rattling around.
And, what's all this about a 'blue' bag? Mine is black vinyl.
supercass
Postby supercass » 12 Dec 2011 01:10
<font size="1">Well Randy. AFAIK the spare sat face down with a rubber strap across to secure it. The jack itself sits against the bulkhead partly resting on the tyre, with the jacking point (piece with the hole) facing rearwards - there should be a separate rubber strap to secure it.
Tony </font id="size1">
Mine has a smaller strap above the strap for the jack, to hold the wheel wrench. supercass
rgsSpider
Postby rgsSpider » 12 Dec 2011 02:24
The rubber pad is missing so I used some sticky-back felt and stuck it to the firewall, works perfect! I hate things rattling around. I used this same felt to make a liner for the center console and glove box, looks like it came from the factory like that!
Who knows about the blue bag, maybe it depends on the year, or the factory, or perhaps who was working that day. Check my website link and click on "The Journey" link, it takes you to the blog. I posted some pics of the blue bag there.
Randy
Postby Hasbeen » 12 Dec 2011 02:42
I have a quarter inch thick pad of rubber conveyor belt on the base of my jack.
As the jack doesn't fit too well with a wide wheel spare, I store my jack vertically in the well on the drivers side [right over here], of the boot/trunk.
With the rubber pad on the base out against the inside of the fender, the top against the floor of the boot, & just enough tension on the winder to lock the thing in place, it is easy to get at, never moves, & doesn't distort the fender.
Users browsing this forum: No registered users and 375 guests
