tr7 non start
davey123
tr7 non start
Postby davey123 » 06 Dec 2011 04:28
hi all new here
just bought a 1977 drophead 2lfr partly restored
upon trying to start engine i found i had no spark upon investigation i found the wiring loom had been chopped and all wires between dist and coil were non existent could anyone help with any info regarding what wire i need and connectios i need to make fo get a spark at the points also any other components that should be present as it only has the coil have read workshop manual but cant make any sense of it any help would be very much apprieciated
Stag76
Postby Stag76 » 06 Dec 2011 07:25
There should be a connection from the negative side of the coil to the points. The Tacho signal also attaches to the negative side of the coil. The positive side of the coil is connected via a ballast resistor to a 12v supply switched by the ignition switch.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
davey123
Postby davey123 » 06 Dec 2011 07:39
erm right will see if i can find any wires of this description many thanks for the reply will let you know how i get on
Stag76
Postby Stag76 » 06 Dec 2011 09:58
If the starter operates, you can temporarily hot-wire it as follows to get it runnning.
Connect a wire from the battery positive terminal to the coil positive terminal.
Connect a wire from the Coil negative terminal to the distributor (points).
TR7 Convertible
Sprint Motor
MegaSquirt EFI
davey123
Postby davey123 » 06 Dec 2011 10:50
thanks guys am gonna try this afternoon and see what happens many thanks guys
Users browsing this forum: No registered users and 175 guests
