choke cable
mitchelltjohn
choke cable
Postby mitchelltjohn » 13 Nov 2011 22:08
I have two std 2.0L UKspec TR7s, one an 1979 early Canley model and an 1981 Solihull model. The choke cables are different, earlier car has a twist lock cable and later car a simple pull cable.
The twist lock cable was stiff so I (foolishly) sprayed WD40 around knob. Its not stiff now however, the twist lock is slipping which isn't helpful during cold running!
Any hints how to make my twistlock choke cable grip again?
Also I've been looking for new cables but only see twist lock version available. In my experience the simple pull cable is more pleasent to use, where can I get one?
Also I assume the simple pull cable were a late introduction on teh TR7 production run - would simple pull cable be out of place in a 1979 early Canley model ?
all dumb and trivial questions I know, but any replies appreaciated...
standard 1981 DHC
Postby busheytrader » 14 Nov 2011 02:57
I did the same thing over 20 years ago to my choke cable.......and ended up replacing it as the twist lock no longer gripped the cable no matter what. Maybe pulling out the cable and wiping it with a solvent might help yours.
As for originality over practicality, I wouldn't worry about late or early choke cable myself. If you prefer it, buy it, fit it.
Users browsing this forum: No registered users and 336 guests
