TR7 starting issue
Postby john 215 » 27 Oct 2011 21:11
Can you hear a clicking from the glovebox when you attempt to start her, i assume the starter is not working, if no clicking noise then poss starter relay or wiring to and from it. Not unknown to fail.
1976 Speke FHC Beauty
Postby saabfast » 27 Oct 2011 21:12
If all the connections on the starter are OK (check the spade connection on the small one, they corrode inside) its most likely the starter relay. Hides to one side of the fuses at the back of the glovebox, often blue in colour IIRC. Try cleaning the terminals. Its slightly different from a standard relay (= costs more from the specialists), I couldn't get it from the local factor. With mine, I had it dangling into the passenger footwell for a while with the top loosely fitted. To start just turned the ignition on and worked the relay with my fingers.
Saab 9000 2.3 FPT Auto
Postby FI Spyder » 28 Oct 2011 01:02
Yah I had the same problem, not dirty starter wire connections, not solenoid, not relay but the connection block that plugs into starter relay was dirty/corroded. I had cleaned it but had to clean it again after an initial complete car wide connector cleaning a year earlier.
