Rear screen removal & replacement
paulheritage
Postby paulheritage » 27 Sep 2011 00:22
Having had a DHC for the last 20 years and 2 x FHC's for only the last year, I've never had the need to take out a rear screen but now the need arises.
I need to make a small repair which means the rear screen should come out and looking for some advice on the best way to remove so I can later replace with damaging the glass or rubber surround.
Advice appreciated.
Cheers Paul,
1976 TR7 FHC (ACG 3115)
1980 TR7V8 3.5 DHC
www.Triumph-Cars.co.uk
All on the road and currently working!
Postby Hasbeen » 27 Sep 2011 02:02
Paul, I pushed mine out by lying on the seats, & using my feet.
I was frightened it may brake, so wore soft soled, ankle high slippers, to protect myself, & it.
It was quite easy. I pushed near the top, which eased out gently, then worked it out with a assistant outside to stop it falling.
Used the string in the moulding system to put it back, no trouble.
paulheritage
Postby paulheritage » 28 Sep 2011 19:29
Thanks for the advice - sounds easy, bet I break it [:)]
Cheers Paul,
1980 TR7V8 3.5 DHC
Postby Maxwell » 28 Sep 2011 20:14
Paul....
Where you based? I've a spare rear screen and a used rubber going begging. A small donation to my Mongol Fund will secure, and I mean small! I'm in SE England, and the glass is green-tinted. Was thinking of dumping it. LOL
3.5 TR7 V8 Drop Head \ Oliver
0.7 Smart Roadster \ Oscar
Users browsing this forum: No registered users and 161 guests
