Ignition key switch replacement
hubbub
Postby hubbub » 21 Sep 2011 12:48
How do you remove the two strange bolts oe what ever they are to replace the key ignition switch?
Postby FI Spyder » 21 Sep 2011 14:42
The strange bolts are bolts that have the heads sheared off as they are tightened (so they can't normally be removed). Take a Dremel with cutting disc and cut a slot in the middle of rounded head. Use a big screwdriver to remove bolt. You tighten them back up that way.
Users browsing this forum: No registered users and 325 guests
