Magnecor leads
macmattom
Magnecor leads
Postby macmattom » 14 Jul 2011 07:04
<font face="Comic Sans MS"><font size="2">I firmly believe in credit where credit's due, and so I thought I'd share with you my experience with Magnecor .
I recently purchased a set of their kv85 leads for my 8V engine (because they were red, which matched the engine bay detailing!). They arrived promptly and looked the business. I then subsequently forgot to put the connecting drive-rod from the dizzy to the oil pump, so when I started the engine I did it no favours. I decided to bite the bullet and remove the 8V engine and replace it with a 16V spare I had.
As I hadn't used the Magnecor leads, I contacted the company directly and asked if they would take them back and swap them for a set for the 16V. Phil was brilliant; the help and support he gave me was way beyond what I had expected. Nothing was too much trouble and he agreed to do the swap for a minimal handling fee and put the 8V leads back on the shelf. I can't thank him enough, but can try.
I just want to say a really big thanks to Magnecor and Phil for being so helpful, and would recommend them to anybody. His knowledge and patience certainly made up for my inexperience and I hope to have the engine running very soon (different story - took the head off for a look-see and discovered a crack piston!).
Anyway, thanks Phil, much appreciated.<font color="blue"></font id="blue"></font id="size2"></font id="Comic Sans MS">
(4 and 1/2 years and counting - but who's counting!!)
staningrimsby
Postby staningrimsby » 14 Jul 2011 07:56
Its allways nice to have a contact at these places Mac,
I am also going to be after some magnacor leads in the near future as im starting to plan all the winter job i need to do to Polly.[:D]
1980 2.0 16v DHC - Polly.
Postby Wayne S » 14 Jul 2011 10:08
Mac, I too had similar experiences with Magnecor.
I bought a set for the V8 and fitted them, 12 months later I swapped the distributor over from the standard Lucas one to a Mallory unit which needs HEI style fitting at the distributor end (basically spark plug fittings on the distributor cap).
I removed the whole set of Magnecor leads and sent them back to Phil at Magnecor who for a minimal labout and parts cost modified my set of leads to fit the new dizzy.
Really helpful and supportive, mainly due to them being a little cottage industry style business on an industrial estate in the UK.
Postby DNK » 14 Jul 2011 13:35
Gee. I should do something about mine then.
After installing them and finishing a top end rebuild I started it and had a clacking noise. I pull a couple of leads off the plugs to find the cylinder and and the end came off one and pulled loose on another. I was even using a boot puller.
Tried to fix one but never new if they where correct or not.
"No More Cars For You"
71 TR6- Perpetual remodel
Users browsing this forum: No registered users and 71 guests
